Slarm64 on Pinebook [Slackware Arm - 64 bit]
#20
Ha, awesome to hear that it works on the PinePhone!  I have not bought one of those yet, but if I did I would probably try the same thing.  Nice work acid andy!  Cool
A few updates after testing my "stable" 5.6.19 images (above) for a while.
1)  You need to make sure that your user is in the gpio group for the LCD brightness script to  work right.  I think I forgot to mention that in the main post.
2)  Sometimes, for unknown reasons, if the X server goes to sleep, it does not come back on fully.  The backlight comes on, but the display never kicks back on.  I get a backlit black screen.  I have to leave it for a long time for this to happen, and it does not happen all the time.  A temporary workaround is to run the command:
xset s off -dpms
as a startup command in whatever DE/WM you are using (in my case, JWM).  This keeps the display from going to sleep at all.  That command might be overkill, perhaps only one or the other options is needed.  But this way, I can manually lock my screen or start a blank screensaver with a key shortcut and it comes back on every time reliably now.  So, the 5.6.19 kernel does not play well with X and energy star settings, or something like that.  I did not have this issue with the 5.5.19 kernel that I upgraded from, but it seems like a simple-enough bug to workaround, so I have not investigated any further.  Nothing is showing up in Xorg.0.log at least.
If anyone has a better fix, I would love to hear it.
Other than those two points, this 5.6.19 "stable" image has been working nicely for me.  YMMV, as always.
RE: Slarm64 on Pinebook [Slackware Arm - 64 bit] - by KRT - 11-16-2020, 10:38 AM
  DietPi OS for Pinebook MichaIng 3 5,502 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 945 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 736 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,809 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 3,267 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,923 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,300 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,849 01-20-2021, 11:18 AM
Question Ran apt update on my Pinebook.. ford442 0 2,823 12-25-2020, 04:40 PM
Last Post: ford442
Information Manjaro ARM for Pinebook erchache2000 88 114,538 11-29-2020, 04:36 PM
Last Post: Mr.Fermer
