Gnome image 2020-02-28
First of all, many thanks to whoever tried to put this image together. I am working on it as well.
However, it does not seem to let me log in (neither as the existing Linux User nor as "Not listed" using "demo").
I also notice that this installation does not seem to use the Mali400 driver, with the result that the screen elements are too big.
I have been trying to work on this as well, but am still struggling to get PMOS to start in Gnome natively.
These are the steps to replicate what I did:
1. Install 2020-02-18 phosh but DO NOT update/upgrade. Make sure your Wifi works.
2. Now install Gnome with
sudo apk add gnome
sudo apk add gnome-apps
Here I am encountering the first problem: Installing gnome-apps gives me an error message that it "breaks mesa-dev-19.3.4-r1" but never mind, it does not seem too serious.
Next, install a new user in Phosh, under Settings / Details / Users. I used just "tester" / "tester"
Then start Gnome with
sudo rc-service gdm start
When prompted, log in with "not listed" and use the credentials listed above.
What you get is a high resolution display which - admittedly - needs good eyesight, but everything fits nicely on your screen. Under Settings / Details / About, you should see "Graphics: Mali400" (which is not the case under Phosh)
Under Settings / Univeral Access, you can tweak some settings for better visibility (try Large Text to start with).
You can install common programmes quite nicely. Try LibreOffice, Thunderbird and GParted for instance.
But I have not been able to start this natively. If I try anything else, I get the low resolution display apparently used in the image that has become available today.
Can I also make a general suggestion please: Sometimes, when I do update/upgrade, the boot partition runs out of space. Perhaps it should be increased to something like 200 MB?
And since the phone's internal memory is 16 GB, perhaps the images should take this into account instead of limiting to 2 GB? SD cards are very cheap nowadays, 16 GB is not going to break the bank.
Gnome image 2020-02-28 - by Zweitaktmotor - 02-28-2020, 06:46 PM
RE: Gnome image 2020-02-28 - by p1trson - 02-29-2020, 10:00 AM
RE: Gnome image 2020-02-28 - by Zweitaktmotor - 02-29-2020, 10:14 AM
RE: Gnome image 2020-02-28 - by MartijnBraam - 02-29-2020, 10:28 AM
RE: Gnome image 2020-02-28 - by Zweitaktmotor - 02-29-2020, 11:52 AM
RE: Gnome image 2020-02-28 - by Danny - 03-02-2020, 06:14 AM
RE: Gnome image 2020-02-28 - by p1trson - 02-29-2020, 10:49 AM
RE: Gnome image 2020-02-28 - by PureTryOut - 03-03-2020, 04:10 AM
  Gnome mobile user641 1 649 01-06-2024, 11:06 AM
Last Post: Uturn
  NextCloud Gnome Mobile Uturn 4 1,202 12-03-2023, 07:54 AM
Last Post: Uturn
  Software app in postmarket gnome shell Uturn 1 622 09-06-2023, 05:27 AM
Last Post: alaraajavamma
  gnome-firmware-updater not found (mirrors) wizardry 1 1,433 03-22-2022, 12:30 PM
Last Post: wizardry
  Where is the original PM OS image for Pinephone? mw4jet 1 2,632 03-14-2021, 07:37 AM
Last Post: ludix
  PMOS test image: failed EG25 test broke modem fw MtnSk8 4 5,728 02-28-2021, 02:20 PM
Last Post: MtnSk8
  Is a Software update the same as instaling an updated image Word5 1 2,940 09-19-2020, 10:23 PM
Last Post: jmorris
  Incorrect Passphrase - FIx | How To Reinstall Image. NobodyNew1 0 2,140 09-02-2020, 09:30 PM
Last Post: NobodyNew1
  sxmo image Verizon calls and SMS work! Saliency 8 8,706 08-22-2020, 03:28 AM
Last Post: PureTryOut
  Latest Installer Image hangs after updates u20200719 4 5,672 07-22-2020, 11:35 AM
Last Post: u20200719
