Wifi- dongle
(02-17-2020, 10:28 AM)wdt Wrote: OK, a tip.  On another (linux) computer lsusb,, note (write down)
vendor id:product id  (nnnn:NNNN) for usb wifi dongle
On pbp, cd /lib/modules
grep -r NNNN *
If you get nothing,, not supported
Yes, I know this doesn't really help buying a new one,
you have to read ad very closely, you can look in modules.alias,
using search, for specific chipsets
Thanks for the feedback: I got  `Realtek RTL8188CUS` with id nnnn:7811
I then check for the modules and get the following:
4.4.210/modules.alias:alias usb:v7392p7811d*dc*dsc*dp*ic*isc*ip*in* rtl8192cu
Binary file 4.4.210/kernel/drivers/net/wireless/rockchip_wlan/rtl8723ds/rtl8723$
Binary file 4.4.210/kernel/drivers/net/wireless/rockchip_wlan/rtl8822be/8822be.$
Binary file 4.4.210/kernel/drivers/net/wireless/rockchip_wlan/rtl8192cu/rtl8192$
4.4.213/modules.alias:alias usb:v7392p7811d*dc*dsc*dp*ic*isc*ip*in* rtl8192cu
Binary file 4.4.213/kernel/drivers/net/wireless/rockchip_wlan/rtl8822be/8822be.$
Binary file 4.4.213/kernel/drivers/net/wireless/rockchip_wlan/rtl8192cu/rtl8192$
It appears that the `rtl8192cu` driver is for the rtl8188cus dongle.
So what happens when I plug it in is the following:
-- for a second or two everything is fine
-- then the mouse cursor stops and everything freezes
-- nothing works and I have to reboot by pressing the off button for a bit
Is there a way for me to check what happened, e.g. what error message caused the freeze ?
Edit: When booting with the dongle plugged in. I am stuck on a black screen.
Wifi- dongle - by User 15552 - 02-17-2020, 09:52 AM
RE: Wifi- dongle - by tophneal - 02-17-2020, 09:54 AM
RE: Wifi- dongle - by wdt - 02-17-2020, 10:28 AM
RE: Wifi- dongle - by User 15552 - 02-18-2020, 02:22 AM
RE: Wifi- dongle - by jiyong - 02-17-2020, 10:44 AM
RE: Wifi- dongle - by wdt - 02-18-2020, 11:35 AM
RE: Wifi- dongle - by User 15552 - 02-19-2020, 03:59 AM
RE: Wifi- dongle - by jiyong - 02-19-2020, 12:57 PM
RE: Wifi- dongle - by wdt - 02-19-2020, 03:11 PM
RE: Wifi- dongle - by User 15552 - 02-26-2020, 02:19 AM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 832 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 613 03-11-2023, 03:21 PM
Last Post: filip
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 2,039 10-08-2022, 06:22 PM
  WiFi Signal Strength? B34N 1 1,233 07-22-2022, 01:35 PM
Last Post: poVoq
  wifi hotspot ip address symbol.accounting@gmail.com 1 1,923 11-07-2021, 12:58 AM
Last Post: dukla2000
  Wifi Troubles IDEFK 17 15,080 05-24-2021, 05:03 AM
Last Post: walterbe
  Pinebook pro poor performance on 5Ghz WiFi Iolaum 10 13,515 05-23-2021, 04:35 AM
Last Post: Ralim
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 3,251 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
  Wifi very slow on PBP Manjaro? WeaseleyRon 2 3,086 01-21-2021, 10:21 AM
Last Post: moonwalkers
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,836 01-17-2021, 01:50 PM
Last Post: BananaPekan
