WiFi Signal Strength?
I have a Pinebook Pro from the original first batch. I've noticed that the WiFi signal strength is much lower on the PBP than with my other devices. This happens in both 2.4 and 5 GHZ. I re-seated the antenna connector and that didn't change anything. I'm running Manjaro with all the latest updates. I have disabled Bluetooth (through the GUI) and that didn't seem to help. Is there anything else that I should be trying?
Yes, I'm just noticing the signal weakness now because I've only recently started taking the PBP with me to places where I need to use public WiFi.
Thank you,
B34N
2.4ghz seems fine, 5ghz has some known connection issues on certain bands.
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 795 07-13-2023, 01:50 PM
Last Post: PaulQ
  wifi missing some networks filip 0 578 03-11-2023, 03:21 PM
Last Post: filip
  Suggestion / Warning about closed source wifi and keyboard / touch pad firmware omarcomputing 3 1,941 10-08-2022, 06:22 PM
  wifi hotspot ip address symbol.accounting@gmail.com 1 1,868 11-07-2021, 12:58 AM
Last Post: dukla2000
  Wifi Troubles IDEFK 17 14,783 05-24-2021, 05:03 AM
Last Post: walterbe
  Pinebook pro poor performance on 5Ghz WiFi Iolaum 10 13,320 05-23-2021, 04:35 AM
Last Post: Ralim
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 3,192 02-05-2021, 09:10 AM
Last Post: BlueJayLinux
  Wifi very slow on PBP Manjaro? WeaseleyRon 2 3,027 01-21-2021, 10:21 AM
Last Post: moonwalkers
  is it possible to get wifi monitor mode on the pbp? BananaPekan 0 1,808 01-17-2021, 01:50 PM
Last Post: BananaPekan
  Wifi stopped working after updates pineitup 10 11,044 11-07-2020, 02:59 AM
