Flash dhivael's SPI uboot (risky)
#22
(02-08-2020, 11:59 AM)Wizzard Wrote: Now I have a problem that I cannot go to maskrom neither loader mode. When I connnect the cable I do not see any device in rkdeveloptool. No matter if PBP is on or off or whether I press the recovery button on PCB prior connecting the cable.
As far as I am aware, maskrom mode will not happen unless there are no bootable devices available. if you have everything else unplugged, the only possible bootable culprit would be your SPI. If your SPI is corrupted, you will need to bypass it by shorting ground to clock. I think that will be the only way you can get into maskrom at this point. good luck!
Flash dhivael's SPI uboot (risky) - by clover - 02-06-2020, 10:42 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 12:40 AM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 12:52 AM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 01:18 AM
RE: Flash dhivael's SPI uboot - by amiraeva - 02-07-2020, 09:42 AM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:04 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 02:42 PM
RE: Flash dhivael's SPI uboot - by User 15997 - 02-07-2020, 02:34 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 02:40 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 02:53 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:05 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 03:39 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 03:57 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-07-2020, 04:11 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 04:12 PM
RE: Flash dhivael's SPI uboot - by Wizzard - 02-07-2020, 04:23 PM
RE: Flash dhivael's SPI uboot - by as400 - 02-08-2020, 06:36 AM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 05:08 PM
RE: Flash dhivael's SPI uboot - by clover - 02-07-2020, 05:42 PM
RE: Flash dhivael's SPI uboot - by pinebro - 02-07-2020, 06:27 PM
RE: Flash dhivael's SPI uboot - by clover - 02-08-2020, 01:37 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 12:36 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 12:25 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 01:46 PM
Flash dhivael's SPI uboot (risky) - by Wizzard - 02-08-2020, 02:02 PM
RE: Flash dhivael's SPI uboot (risky) - by clover - 02-08-2020, 02:13 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 02:07 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-08-2020, 03:35 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 01:55 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:27 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 02-09-2020, 02:46 PM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-12-2020, 11:16 AM
RE: Flash dhivael's SPI uboot (risky) - by vrabac - 03-13-2020, 12:12 AM
RE: Flash dhivael's SPI uboot (risky) - by as400 - 03-14-2020, 08:04 AM
  How to rewrite uboot to emmc pineitup 5 9,019 12-27-2020, 10:35 AM
Last Post: nightranger73
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,764 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,487 09-21-2020, 10:02 AM
Last Post: hmuller
  In-Circuit Programming of SPI NOR Flash hmuller 13 18,575 09-13-2020, 01:20 PM
Last Post: hmuller
  Installing Ubuntu 20.04 (Focal) with BSP uBoot with deep sleep and sound Syonyk 43 54,598 07-28-2020, 03:18 PM
Last Post: SamWilts
  How to boot Manjaro from NVME with uboot on eMMC as400 47 57,816 06-07-2020, 02:37 AM
Last Post: as400
  (almost) upstream uboot/atf User 15997 27 31,666 02-08-2020, 10:18 PM
Last Post: Natrox
  Widevine-flash on Chromium-SD Card mamboman777 3 6,549 01-20-2020, 04:00 PM
