Widevine-flash on Chromium-SD Card
I was able to get Amazon Prime video working today on Chromium booted from an SD Card.  I used this script: https://gist.github.com/ruario/19a28d98d...42e5f8bf29
Extracted the .tgz file.  and copied the contents into the /opt/google/chrome folder of the partition labeled Root-A of the SD card which I have Chromium OS.
I have tested with Amazon Prime, but I don't have a netflix account. I imagine all widevine streams would work now.
When using ayufan's Chromium, also check out these scripts: https://github.com/ayufan-rock64/chromiu...es/scripts
Both are accessible through the terminal. One will resize STATE to fill the available space, and the other installs Widevine.
Quote:1. Resize STATE
After installing Chromium OS you should resize STATE partition:
Press: Ctrl+Alt+F2,
Login: chronos/chronos,
Run: sudo rockpro64-resize-statefs.sh, enter password chronos,
Exit and go back to the Chromium OS with Ctrl+Alt+F1.
2. Install Widevine DRM
The build supports Widevine DRM, but does not ship the binary as this is against Google license. You can install it manually, but first follow the resize manual:
Press: Ctrl+Alt+F2,
Run: sudo rockpro64-install-widevine.sh,
Reboot: sudo reboot.
(01-20-2020, 02:05 PM)tophneal Wrote: When using ayufan's Chromium, also check out these scripts: https://github.com/ayufan-rock64/chromiu...es/scripts
Press: Ctrl+Alt+F2,
Press: Ctrl+Alt+F2,
Nice! Of course I didn't know about them. I just used gparted from bionic on the eMMC. I tend to just stick with the familiar. ?
Yea, is not included inside a readme in the repo, so it can be very easy to miss if you don't know it's there.
  How to enable widevine in firefox (PrimeVideo) sirspate 18 33,861 12-01-2023, 06:52 AM
Last Post: Tazdevl
  Tinkering with docker-chromium-armhf to use any armhf program e.g. vncviewer wrzomar 0 2,664 09-30-2020, 02:07 PM
Last Post: wrzomar
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,735 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,457 09-21-2020, 10:02 AM
Last Post: hmuller
  In-Circuit Programming of SPI NOR Flash hmuller 13 18,343 09-13-2020, 01:20 PM
Last Post: hmuller
Exclamation Flash dhivael's SPI uboot (risky) clover 51 53,377 06-20-2020, 03:24 PM
Last Post: craftkiller
