full disk encryption with luks on manjaro xfce
#42
(06-23-2020, 12:49 PM)Proant Wrote:
(05-24-2020, 12:04 AM)e-minguez Wrote: Those errors are harmless, it cannot find some modules but that's ok.
Glad to hear it worked!
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
Ok, so just to make sure I am reading this thread right..
If I want to change the default Manjaro install on my brandnew Pinebook Pro and change it with a version that has full disk encryption what I should do is:
* Boot my PBP via an SD-card that had a pre-installed live OS on it.
* Make sure my eMMC memory in not mounted (and emptied out? How should I best do that?)
* On the live OS install the dependencies lister here and follow the instructions for "[url=#installing-and-using-from-manjaro-x64-repositories][/url]Installing and using from Manjaro x64 repositories" using the export CRYPT option as described there.
*  Shutdown my PBP, remove the SD, reboot and.. voila?
Or am I misinterpreting the entire thing?
I'm afraid it is not that easy Smile you should create a new image using the manjaro-arm-installer repo. See the instructions there.
RE: full disk encryption with luks on manjaro xfce - by e-minguez - 06-23-2020, 01:12 PM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,202 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,801 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,298 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,241 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,481 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,950 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,887 07-13-2020, 03:13 AM
Last Post: brent.thierens
  kernel build script for latest mainline manjaro kernel xmixahlx 42 59,388 07-11-2020, 09:01 PM
Last Post: xmixahlx
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 8,070 06-23-2020, 12:41 AM
Last Post: pljanson
  How to boot Manjaro from NVME with uboot on eMMC as400 47 57,954 06-07-2020, 02:37 AM
Last Post: as400
