kernel build script for latest mainline manjaro kernel
(04-20-2020, 06:40 PM)xmixahlx Wrote: strange. i use a modified and minimalized danielt installer so some components are disabled, and i also use debian sid arm64. are you otherwise having a problem with systemd tempfiles?
also, 5.7-rc2 working well for me with the patch and config above.
It is just with the custom kernel + config. I tried your patch for the installer you posted earlier, but some changes already are merged and some don't apply cleanly  anymore. I couldn't figure out quickly what to keep and what to change so I went ahead with danielt's installer. I will try again with the 5.7-rc2 kernel but I assume it will be the same. Could you maybe post your install script? I have no issues with running sid.
Edit: I realised the patch for the installer is in another thread, this one: https://forum.pine64.org/showthread.php?...6#pid58996
Edit 2: I got it working by compiling the kernel on the pinebook instead of cross compiling, which is better than nothing for now. Still struggling to get hardware decoding working for h264 1080p.
RE: kernel build script for latest mainline manjaro kernel - by termac - 04-21-2020, 12:47 AM
  Building PPSSPP with Manjaro AUR LivingLinux 0 1,193 06-11-2022, 05:07 PM
Last Post: LivingLinux
  How to update Manjaro to 20.10 pineitup 8 13,752 07-31-2021, 04:44 AM
Last Post: jiyong
  Make your own Manjaro image flatulent_piney 0 3,284 11-07-2020, 03:30 AM
Last Post: flatulent_piney
  Manjaro ARM, Cryptomator, and MEGA Sync dp1kinobe 3 7,227 10-24-2020, 06:38 AM
Last Post: pineitup
  Downgrading packages on Manjaro ARM (on the example of boinc) wrzomar 0 3,475 10-02-2020, 12:20 PM
Last Post: wrzomar
  Freepascal FPC3.20 and Lazarus IDE on Manjaro KDE dieselnutjob 0 2,942 08-02-2020, 06:57 AM
Last Post: dieselnutjob
  Installing WPS Office on Manjaro brent.thierens 5 9,864 07-13-2020, 03:13 AM
Last Post: brent.thierens
  full disk encryption with luks on manjaro xfce limxr 48 68,763 07-09-2020, 07:27 AM
Last Post: JtR
  Is there a MMC upgrade instruction from debian-mate to manjaro factory (20.06)? pljanson 4 8,051 06-23-2020, 12:41 AM
Last Post: pljanson
  mesa-git build script for latest panfrost xmixahlx 28 48,168 06-11-2020, 11:16 PM
Last Post: xmixahlx
