Sound driver 32bit sample format not working, some freezes and crashes through ALSA
I got a new PinebookPro last week and did not change much except installing jackd 2.
I noticed that the sound was totally wrong, not in a distorted sense but technically wrong. After some investigation, actually some hours with ALSA devs in freenodes #alsa channel, they came to the conclusion, that there is some need for clarification and/or work to do.
Bottom line question is:  Does the PinebookPro hardware support the 32bit float sample format?
If yes there is something wrong with the driver.
What follows is a curated alsa report summary with annotations from the alsa devs.
I hope this information will be useful in creating a better software revision for units shipped in the future:
[color=#000000]`aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:es8316spksound /dev/urandom`
*sympbolic card name does not work
`aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:0 /dev/urandom`
*no front pcm
`aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:0 /dev/urandom`
*system crash and reboot when accessing alsa directly with pulseaudio running
`pasuspender -- aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:0 /dev/urandom`
*conflict between sample bits and sample format
ACCESS:  MMAP_INTERLEAVED RW_INTERLEAVED
FORMAT:  S16_LE S24_LE
SUBFORMAT:  STD
SAMPLE_BITS: [16 32]
FRAME_BITS: [32 64]
`pasuspender -- aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S32_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=hw:0,0 /dev/urandom`
Playing raw data '/dev/urandom' : Signed 32 bit Little Endian, Rate 48000 Hz, Stereo
HW Params of device "hw:0,0":
SUBFORMAT:  STD
FRAME_BITS: [32 64]
CHANNELS: 2
RATE: [8000 96000]
PERIOD_TIME: (333 8192000]
PERIOD_SIZE: [32 65536]
PERIOD_BYTES: [256 524288]
PERIODS: [2 4096]
BUFFER_TIME: (666 16384000]
BUFFER_SIZE: [64 131072]
BUFFER_BYTES: [256 524288]
TICK_TIME: ALL
aplay: set_params:1299: Sample format non available
Available formats:
- S16_LE
- S24_LE
`pasuspender -- aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --device=front:aplay --file-type=wav --channels=2 --format=S16_LE --rate=48000 --duration=5 --verbose --dump-hw-params --mmap --device=hw:0 /dev/urandom`
(09:59:40 AM) nilshi: that crashed
*mmap makes the machine reboot sometimes and other times hang up temporarily
*summary the driver has numerous issues[/color]
Sound driver 32bit sample format not working, some freezes and crashes through ALSA - by aeGh7fae - 01-28-2020, 10:16 AM
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 647 11-22-2023, 11:47 AM
Last Post: fxc
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 830 07-13-2023, 01:50 PM
Last Post: PaulQ
  bliuetooth not working in Armbian 22.11.1 Pinebook Pro River 0 795 12-09-2022, 04:48 PM
Last Post: River
  Pinebook Pro freezes when running on battery petaramesh 5 2,689 09-22-2022, 12:43 AM
Last Post: petaramesh
  alarming sound coming from pinebook pro jazzhands 2 1,684 08-21-2022, 02:34 PM
Last Post: foobar
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 2,454 06-29-2022, 02:00 PM
Last Post: Chief
  Article: Build a Linux Driver for PineDio LoRa SX1262 USB Adapter lupyuen 3 3,195 05-26-2022, 11:09 PM
Last Post: lupyuen
  My Experience Using the Pinebook Pro as a Daily Driver warpnow 9 9,181 06-22-2021, 02:30 PM
Last Post: moonwalkers
  If booted with headphones in, sound comes from them and speakers stozi 6 5,636 06-11-2021, 01:27 AM
Last Post: dsimic
  [driver dev] SDMMC , not behaving mgrunditz 3 2,944 05-16-2021, 06:41 AM
Last Post: dsimic
