Booting from an SD card without the boot order update
I got a Pinebook Pro the other day.
I was getting no sound, and although wifi worked, the USB C hub with ethernet wasn't working either. I was going to try Manjaro, as someone on the fourm suggested, but I had an idea first: I'll just upgrade from strech to buster! Interestingly, the packages were mostly armhf, although there were a few arm64.
After trying to upgrade, something went wrong. The next time that I rebooted, I got an unblinking cursor at the top left after seeing a Debian login console for a fraction of a second.
I made the Manjaro SD card, but it doesn't look like the SD card is read. I saw in another post that there is an update that I should have done before anything else.
I'm guessing that what I need to do is open it up and disable the eMMC, and hope that doing so will make it no longer participate in the boot order.
I'd like to know for sure what I'm doing before opening it; can someone point me to a document that says where the dip switches are and what they do?
Booting from an SD card without the boot order update - by jaysistar - 01-24-2020, 09:46 PM
  uboot wont boot to SD card after upgrade jbradley419 7 880 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 301 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,251 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 708 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 601 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,207 09-19-2023, 08:48 AM
Last Post: dachalife
  After update, multiple problems, pinebook pro. jd50i 1 1,054 09-16-2023, 09:41 AM
Last Post: jd50i
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,910 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 811 07-13-2023, 01:50 PM
Last Post: PaulQ
  Order Status mamboman777 1 3,594 06-17-2023, 10:25 AM
Last Post: fxc
