Connected to 4k (3840x2160) monitor but I can only select upto 1920x1080 resolution
From reading the monitor's manual, it does seem like it should work. It's possible it's a software issue on the Pinebook Pro.
If you do buy an adapter, make sure you buy a USB-C to alternate mode Display Port. (Make sure it supports 4 lanes / 4K @ 60hz.) Then use a Display Port to Display Port cable.
In theory you can get a USB-C to alternate mode Display Port, but with a built in active converter to HDMI. However, this makes little sense, because the Pinebook Pro and your monitor have native Display Port options.
Last, if you want 4K @ 60hz, any USB C dock on your Pinebook Pro must be limited to USB 2 speeds. Meaning the two USB 3 lanes would be needed for the video. There are a few out there, either fixed at USB 2 speeds, or have a switch to enable / disable USB 3.
Arwen Evenstar
Princess of Rivendale
RE: Connected to 4k (3840x2160) monitor but I can only select upto 1920x1080 resolution - by Arwen - 01-12-2020, 11:22 PM
  External USB C Monitor not working altacus 29 38,997 08-08-2021, 10:19 AM
Last Post: Dendrocalamus64
  Adjusting screen resolution lead to a black screen Linux-Rob 28 27,050 06-27-2021, 02:12 AM
Last Post: Arwen
  Funny Conky like script to monitor your PBP state as400 1 3,303 08-19-2020, 12:57 PM
Last Post: xmixahlx
Question Manjaro XFCE: video outputs (Multi-monitor) EreTIk 2 4,226 03-23-2020, 11:20 AM
Last Post: EreTIk
Bug MATE System Monitor shows seven CPU cores in Debian User 11436 2 4,229 11-07-2019, 11:32 AM
Last Post: hmuller
