Manjaro XFCE: video outputs (Multi-monitor)
Question
Connected USB type C to DP device: it works in mirror mode.
Manjaro XFCE only displays one video output: "default"
$ xrandr -q
xrandr: Failed to get size of gamma for output default
Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080
default connected 1920x1080+0+0 0mm x 0mm
  1920x1080      0.00*
GUI settings ($ xfce4-display-settings -m): only one monitor ("default")
How to configure two separate monitors?
P.S. Default Debian: no problems (eDP-1 and DP-1 video outputs).
(03-22-2020, 11:37 AM)EreTIk Wrote: Connected USB type C to DP device: it works in mirror mode.
$ xrandr -q
  1920x1080      0.00*
that came up a few times on manjaro arm forums
the suggestion was swap drivers :
sudo pacman -S mesa-git
sudo pacman -R xf86-video-fbturbo # or xf86-video-fbturbo-git
then reboot
it worked for me Shy
Thank you very much
But without xf86-video-fbturbo-git, the rendering speed in xfreerdp is very low
  Manjaro Sway Theme Broken Eighty8 1 260 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,719 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 304 01-19-2024, 11:32 PM
  Streaming video sites tessa 1 1,024 01-19-2024, 03:47 AM
Last Post: similarwham
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,071 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,150 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 386 12-07-2023, 03:11 PM
  No Video Out on PBP on all major distros misha64 9 2,719 11-28-2023, 01:41 PM
Last Post: zaius
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 858 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 1,992 08-21-2023, 09:10 PM
Last Post: vanessadonald
