Minimal 64bit ARM RootFS for Debian and Ubuntu
#21
(01-03-2016, 01:58 AM)umiddelb Wrote: Hi,
I've prepared two tar archives containing a minimal 64bit ARM root filesystem for Debian Jessie (login: debian, passwd: 111111) and Ubuntu Trusty (login ubuntu, passwd: 111111). You can find the scripts for creating the root filesystems and some additional information about the tar archives here. Once the kernel image / modules and the boot loader are available for the PINE64, I'll try to build a complete image.
Cheers
Uli
I've updated the information about creating your own bootable Linux uSD card, since kernel & boot loader are available. Debian is first, Arch and Ubuntu are going to follow.
* The PINE64 boots up nicely
* The 3.10 kernel doesn't seem to fry the SoC
* You may run Docker
* You may use the USB ports
* You may start to port your own project to the PINE64
* The kernel is as old as the hills, and not in good shape (you should expect compile errors and broken dependency configuration if you start to tweak it)
* The kernel panics during reboot/shutdown
* The internal ethernet device has a speed issue, you shouldn't expect to get more the several kbit/s over the wire. (best is to connect an USB to ethernet device)
* WiFi isn't working at this time
* You cannot login via serial console, although /dev/ttyS0 is working FIXED: Was missing CONFIG_FHANDLE
* Haven't tested video so far
* May more to be found
RE: Minimal 64bit ARM RootFS for Debian and Ubuntu - by umiddelb - 02-17-2016, 03:17 PM
  Arch, Debian or other for Pinebook? cootcraig 3 6,291 05-01-2019, 09:11 AM
Last Post: cootcraig
  Pine64: Minimal SDL config Max11 3 5,987 01-04-2019, 03:47 PM
Last Post: Max11
  Issues with both Deb and Ubuntu germanshep 0 2,531 08-28-2018, 05:47 PM
Last Post: germanshep
  Help debug my pine64A+ ubuntu/plex hangs XaRz 8 10,019 11-02-2017, 06:34 AM
Last Post: XaRz
  Ubuntu 16.04 cannot resolve dns - connection timed out; no servers could be reached marcosti 2 10,099 03-01-2017, 02:46 PM
Last Post: dkryder
  Pine64 will be supported by HypriotOS (a Debian Jessie based OS for running Docker) Quintus23M 9 16,922 02-03-2017, 05:50 AM
Last Post: pfeerick
Question Ultrawide Display for Ubuntu Mate DE dudeytsang 1 5,024 01-01-2017, 07:26 AM
Last Post: CaptainZalo
  Pine64+Ubuntu+Tvheadend+DVBT Dongle Shai 3 6,397 10-03-2016, 04:23 AM
Last Post: Shai
  Dmesg output Ubuntu Mate S265 1 3,612 10-02-2016, 07:28 AM
Last Post: MarkHaysHarris777
  mounting rootfs Shai 1 3,193 10-01-2016, 07:59 AM
Last Post: waldo
