Mainline U-Boot with SPI, NVMe and SATA boot support
Oh, sorry. I add wrong log.
U-Boot TPL 2020.01-rc5-01969-g0bfd4738c6 (Jan 03 2020 - 15:46:36)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
Channel 1: LPDDR4, 50MHz
256B stride
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.01-rc5-01969-g0bfd4738c6 (Jan 03 2020 - 15:46:36 +0000)
Trying to boot from SPI
NOTICE:  BL31: v2.2(release):v2.2-277-gb1af2a51
NOTICE:  BL31: Built : 15:44:18, Jan  3 2020
U-Boot 2020.01-rc5-01969-g0bfd4738c6 (Jan 03 2020 - 15:46:36 +0000)
Model: Pine64 RockPro64
DRAM:  2 GiB
PMIC:  RK808
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPI Flash... SF: Detected gd25q128 with page size 256 B
*** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
rockchip_dnl_key_pressed: adc_channel_single_shot fail!
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
Device 0: Vendor: 0x144d Rev: 1B2QEXE7 Prod: S466NX0K606125A
           Type: Hard Disk
           Capacity: 476940.0 MB = 465.7 GB (976773168 x 512)
... is now current device
Scanning nvme 0:7...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
2073 bytes read in 4 ms (505.9 KiB/s)
select kernel
1:      kernel-4.4.202-1237-rockchip-ayufan-gfd4492386213
2:      kernel-4.4.202-1237-rockchip-ayufan-gfd4492386213-memtest
3:      kernel-4.4.197-1236-rockchip-ayufan-g30faab37e339
4:      kernel-4.4.197-1236-rockchip-ayufan-g30faab37e339-memtest
Only USB3-Device what is booting from Kamils u-boot is my Samsung T5 SSD and my Corsair GTX USB3-Stick.
I have flashed u-boot to SPI.
What is booting?
  • PCIe NVMe SSD
  • SD-Card
What not?
  • eMMC
  • USB2 / USB3
Thanks for your work. When i can help testing, let me know.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
RE: Mainline U-Boot with SPI and NVMe support (alpha/pre-release version for testing) - by Bullet64 - 01-05-2020, 07:59 AM
  enble boot after power loss/restore dkebler 18 9,605 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 683 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,309 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,403 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,572 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,330 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,164 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,831 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,174 06-09-2022, 10:56 AM
Last Post: pspgarret
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 924 06-02-2022, 02:20 AM
Last Post: dmos
