Mainline U-Boot with SPI, NVMe and SATA boot support
Many thanks for your work!!!
I have seen an booting NVMe device Exclamation  But i got some errors. Tomorrow i will do more tests.....
Update
Works fine! Big Grin
U-Boot TPL 2020.01-rc5-01969-g0bfd4738c6 (Jan 03 2020 - 15:46:36)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
Channel 1: LPDDR4, 50MHz
256B stride
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.01-rc5-01969-g0bfd4738c6 (Jan 03 2020 - 15:46:36 +0000)
Trying to boot from SPI
NOTICE:  BL31: v2.2(release):v2.2-277-gb1af2a51
NOTICE:  BL31: Built : 15:44:18, Jan  3 2020
U-Boot 2020.01-rc5-01969-g0bfd4738c6 (Jan 03 2020 - 15:46:36 +0000)
Model: Pine64 RockPro64
DRAM:  2 GiB
PMIC:  RK808
MMC:   dwmmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPI Flash... SF: Detected gd25q128 with page size 256 B
*** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
rockchip_dnl_key_pressed: adc_channel_single_shot fail!
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:7...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1055 bytes read in 8 ms (127.9 KiB/s)
select kernel
1:      kernel-4.4.197-1236-rockchip-ayufan-g30faab37e339
2:      kernel-4.4.197-1236-rockchip-ayufan-g30faab37e339-memtest
Enter choice: 1:        kernel-4.4.197-1236-rockchip-ayufan-g30faab37e339
Retrieving file: /boot/initrd.img-4.4.197-1236-rockchip-ayufan-g30faab37e339
5143934 bytes read in 224 ms (21.9 MiB/s)
Retrieving file: /boot/vmlinuz-4.4.197-1236-rockchip-ayufan-g30faab37e339
20545544 bytes read in 874 ms (22.4 MiB/s)
append: rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=62:03:b0:d6:dc:b3 4
Retrieving file: /boot/dtbs/4.4.197-1236-rockchip-ayufan-g30faab37e339/rockchipb
96273 bytes read in 17 ms (5.4 MiB/s)
## Flattened Device Tree blob at 01f00000
  Booting using the fdt blob at 0x1f00000
  Loading Ramdisk to 7da26000, end 7df0dd7e ... OK
ERROR: reserving fdt memory region failed (addr=0 size=0)
  Loading Device Tree to 000000007da0b000, end 000000007da25810 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[...gekürzt...]
Filesystem
rock64@rockpro64:~$ df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            960M     0  960M   0% /dev
tmpfs           193M  7.7M  185M   4% /run
/dev/nvme0n1p7  1.9G  1.1G  669M  62% /
tmpfs           963M     0  963M   0% /dev/shm
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           963M     0  963M   0% /sys/fs/cgroup
/dev/nvme0n1p6  112M  4.0K  112M   1% /boot/efi
tmpfs           193M     0  193M   0% /run/user/1000
Attention, you must resize filesystem for
/dev/nvme0n1p7
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
RE: Mainline U-Boot with SPI and NVMe support (alpha/pre-release version for testing) - by Bullet64 - 01-04-2020, 04:10 PM
  enble boot after power loss/restore dkebler 18 9,600 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 683 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,307 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,396 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,571 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,327 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,164 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,831 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,173 06-09-2022, 10:56 AM
Last Post: pspgarret
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 922 06-02-2022, 02:20 AM
Last Post: dmos
