PINE64 to allow use of SATA disk on network/FTP
(11-18-2019, 05:14 AM)mwelbourne Wrote: Right, thanks. So what advantages does a PINE64 or Rock have over a Raspberry Pi? I was recommended to check out PINE because I could connect the SATA to the board directly but this is not the case. But I'm still OK with going the PINE option if there are still other benefits.  What country do PINE/Rock products get posted from?  I think if I order stuff  directly from PINE then the postage costs might make it the more expensive option.
As I mentioned earlier in the thread, the Rockpro64 has a pci-e slot which you can plug in a dual sata card, and connect hdd's that way. The down side is more cost.
The Rpi4 which just came out is similar in price to the rp64, and they both run hot and need heatsinks and/or fans so they don't hit thermal limits etc. Older rpi's shared one USB port for all connections and the ethernet chip. Where as pine boards have gig-e that can actually do 1 Gbit. The r64 has a USB3 connector.
RE: PINE64 to allow use of SATA disk on network/FTP - by evilbunny - 11-18-2019, 05:24 AM
  Pine64 as squeezebox touch replacement Learnincurve 12 28,039 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 9,612 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 3,972 08-06-2020, 12:05 AM
Last Post: tuaris
Information Pine64 Head Unit Zoidiano0 100 142,679 11-19-2019, 04:35 AM
Last Post: rogatip79
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 42,748 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 3,550 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 38,091 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 9,709 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 7,146 02-01-2018, 07:49 AM
Last Post: davidbrucs
Photo Nextcloud running on Pine64 gbjensen 1 6,054 01-18-2018, 05:51 AM
Last Post: Luke
