(11-11-2019, 11:40 PM)hikaricore Wrote: Any chance you had your CPU set to 1.99GHZ? I encountered a similar issue when I first got my Pinebook Pro and it stopped happening when I left the CPU set to Ondemand. Not sure if this is of any help, but I figured I'd speak up in the off-chance that this was a factor.
I suspected that issue would be the case so I have tried it on low, medium and high CPU speeds but have the same problem. Takes 5-15 minutes for the net to drop out and takes a reboot to start working again.
Output from /var/log/syslog
varlogoutput.txt (Size: 51.91 KB / Downloads: 386)
This is why I thought DNS config issues.
