pmbootstrap to sdcard
#34
(11-15-2019, 06:55 PM)Danct12 Wrote: Yep! It's simple as that!
Can you help. I'm all ways get errors when i u mount sd card its says that directory not found when i live it mounted its saying can not format. am i missing some thing? tnx
hp@hp-HP-Laptop-17-bs0xx:~$ pmbootstrap install --sdcard /dev/sdb
[13:44:06] *** (1/5) PREPARE NATIVE CHROOT ***
[13:44:06] *** (2/5) CREATE DEVICE ROOTFS ("pine64-pinephone") ***
[13:44:08] WARNING: aarch64 package 'polkit' installed version 0.116-r2 is newer, than the version in the repositories: 0.116-r1 See also: <https://postmarketos.org/warning-repo>
[13:44:08] (rootfs_pine64-pinephone) install
[13:44:12] WARNING: aarch64 package 'polkit' installed version 0.116-r2 is newer, than the version in the repositories: 0.116-r1 See also: <https://postmarketos.org/warning-repo>
[13:44:12] (rootfs_pine64-pinephone) install
[13:44:15] (rootfs_pine64-pinephone) write /etc/os-release
[13:44:15] (rootfs_pine64-pinephone) install
[13:44:18] (rootfs_pine64-pinephone) install
[13:44:21] (rootfs_pine64-pinephone) mkinitfs postmarketos-allwinner
[13:44:55]  *** SET LOGIN PASSWORD FOR: 'user' ***
New password:
Retype new password:
passwd: password updated successfully
[13:45:23] NOTE: No valid keymap specified for device
[13:45:25] *** (3/5) PREPARE INSTALL BLOCKDEVICE ***
[13:45:25] (native) mount /dev/install (host: /dev/sdb)
[13:45:25] EVERYTHING ON /dev/sdb WILL BE ERASED! CONTINUE? (y/n) [n]: y
[13:45:30] (native) partition /dev/install (boot: 106M, root: the rest)
[13:45:32] ERROR: Unable to find the partition prefix, expected the first partition of /dev/sdb to be located at /dev/sdb1 or /dev/sdbp1!
[13:45:32] See also: <https://postmarketos.org/troubleshooting>
Run 'pmbootstrap log' for details.
[13:46:36] *** (1/5) PREPARE NATIVE CHROOT ***
[13:46:36] *** (2/5) CREATE DEVICE ROOTFS ("pine64-pinephone") ***
[13:46:38] WARNING: aarch64 package 'polkit' installed version 0.116-r2 is newer, than the version in the repositories: 0.116-r1 See also: <https://postmarketos.org/warning-repo>
[13:46:38] (rootfs_pine64-pinephone) install
[13:46:41] WARNING: aarch64 package 'polkit' installed version 0.116-r2 is newer, than the version in the repositories: 0.116-r1 See also: <https://postmarketos.org/warning-repo>
[13:46:41] (rootfs_pine64-pinephone) install
[13:46:45] (rootfs_pine64-pinephone) write /etc/os-release
[13:46:45] (rootfs_pine64-pinephone) install
[13:46:48] (rootfs_pine64-pinephone) install
[13:46:51] (rootfs_pine64-pinephone) mkinitfs postmarketos-allwinner
[13:47:23]  *** SET LOGIN PASSWORD FOR: 'user' ***
New password:
[13:47:31] NOTE: No valid keymap specified for device
[13:47:33] *** (3/5) PREPARE INSTALL BLOCKDEVICE ***
[13:47:34] ERROR: /dev/sdb1 is mounted! We will not attempt to format this!
[13:47:34] See also: <https://postmarketos.org/troubleshooting>
pmbootstrap to sdcard - by Jeb5Blovrueb - 11-11-2019, 02:13 PM
RE: pmbootstrap to sdcard - by Danct12 - 11-15-2019, 06:55 PM
RE: pmbootstrap to sdcard - by vetrik55 - 07-06-2020, 03:17 PM
RE: pmbootstrap to sdcard - by fernando_c_m - 07-07-2020, 04:17 AM
RE: pmbootstrap to sdcard - by wgvanveen - 02-02-2020, 05:18 AM
RE: pmbootstrap to sdcard - by Veraendert - 02-02-2020, 06:30 AM
RE: pmbootstrap to sdcard - by wgvanveen - 02-02-2020, 10:11 AM
RE: pmbootstrap to sdcard - by rico - 02-02-2020, 11:27 AM
RE: pmbootstrap to sdcard - by wgvanveen - 02-02-2020, 11:46 AM
RE: pmbootstrap to sdcard - by rico - 02-02-2020, 11:56 AM
RE: pmbootstrap to sdcard - by ksmithaz1 - 02-07-2020, 08:57 AM
RE: pmbootstrap to sdcard - by colin hodsdon - 02-11-2020, 04:39 PM
RE: pmbootstrap to sdcard - by pajux - 02-07-2020, 09:44 AM
RE: pmbootstrap to sdcard - by albertz - 02-09-2020, 06:44 AM
RE: pmbootstrap to sdcard - by Gobelin - 02-10-2020, 02:48 AM
RE: pmbootstrap to sdcard - by albertz - 02-10-2020, 06:51 AM
RE: pmbootstrap to sdcard - by wibble - 02-10-2020, 05:20 AM
RE: pmbootstrap to sdcard - by albertz - 02-10-2020, 08:45 AM
RE: pmbootstrap to sdcard - by albertz - 02-10-2020, 11:28 AM
RE: pmbootstrap to sdcard - by curtvaughan - 02-10-2020, 02:23 PM
RE: pmbootstrap to sdcard - by MartijnBraam - 02-11-2020, 06:44 AM
RE: pmbootstrap to sdcard - by curtvaughan - 02-13-2020, 09:28 AM
RE: pmbootstrap to sdcard - by curtvaughan - 02-14-2020, 02:14 PM
RE: pmbootstrap to sdcard - by canadien666 - 03-19-2020, 06:40 PM
RE: pmbootstrap to sdcard - by PureTryOut - 03-20-2020, 01:32 AM
RE: pmbootstrap to sdcard - by canadien666 - 03-22-2020, 04:50 PM
RE: pmbootstrap to sdcard - by KeithMcN - 06-22-2020, 03:15 AM
RE: pmbootstrap to sdcard - by PureTryOut - 03-23-2020, 04:06 AM
RE: pmbootstrap to sdcard - by valentin - 04-18-2020, 12:28 PM
RE: pmbootstrap to sdcard - by PureTryOut - 04-19-2020, 09:05 AM
RE: pmbootstrap to sdcard - by valentin - 05-11-2020, 07:37 AM
RE: pmbootstrap to sdcard - by PureTryOut - 06-09-2020, 01:27 PM
RE: pmbootstrap to sdcard - by Saliency - 06-17-2020, 11:10 PM
RE: pmbootstrap to sdcard - by PureTryOut - 06-18-2020, 04:39 AM
RE: pmbootstrap to sdcard - by KeithMcN - 06-21-2020, 12:55 PM
  phone won't boot from emmc with sdcard inserted ssilvi 3 3,704 06-06-2021, 02:47 AM
Last Post: ssilvi
  Cannot boot from SDCard cube 2 3,420 01-31-2021, 11:47 AM
Last Post: cube
  pmbootstrap error lat 2 3,583 12-22-2020, 06:32 PM
Last Post: lat
  pmbootstrap issues IVp 3 5,363 09-24-2020, 02:24 AM
Last Post: Pinethom
  pmbootstrap build large keyboard not usable u20200719 5 7,149 07-25-2020, 02:31 PM
Last Post: u20200719
  Is it possible to pre-configure wifi and ssh with pmbootstrap? kelbot 2 4,759 07-06-2020, 01:55 AM
Last Post: ChriChri
  Dumb question: do I have to use pmbootstrap? quixote 5 7,069 06-11-2020, 09:23 AM
Last Post: plainenough
  pmbootstrap on Mac OSX srfne 2 5,525 02-29-2020, 04:15 PM
Last Post: srfne
  Does pmbootstrap install the latest image? mypine 4 6,260 02-20-2020, 01:02 PM
Last Post: mypine
  pmbootstrap - choose different ui after first run mypine 2 4,086 02-13-2020, 04:35 PM
Last Post: mypine
