DONT INSTALL TO EMMC R77-12371.7.104.g78f88d6 VERSION YET!
(08-14-2020, 04:59 AM)tophneal Wrote: The description of Manjaros behavior sounds correct for s3. I’m not familiar enough with netBSD to help with it.
No it likely isn’t a hardware or assembly issue.
Hi, @tophneal , thank you for your comments!
I still doubt my PBP HW issue because just running 'reboot' command could cause immediate suspend transition as well as login panel.
Also the same netbsd image worked fine when I checked before flashing CrOS...
Anyway thank you so much your advice, I'll spend more time to check my PBP, sigh.
Best regards,
Shoichi
RE: DONT INSTALL TO EMMC R77-12371.7.104.g78f88d6 VERSION YET! - by shoichimiyake - 08-14-2020, 11:38 PM
  Cant login to a new install of ChromeOS flatulent_piney 1 3,633 11-10-2020, 01:19 PM
Last Post: flatulent_piney
  Using Crouton to install Arch tophneal 3 7,445 04-27-2020, 06:23 AM
  R77-12371.7.104 ayufan 26 35,031 11-28-2019, 10:20 AM
Last Post: TDC_PBP
