R77-12371.7.104
Second release of Chromium OS build for Pinebook Pro:
https://github.com/ayufan-rock64/chromiu...4.g78f88d6
The image is compatible with RockPro64 and Pinebook Pro.
Check the compatibility list to see what is supported: https://docs.google.com/spreadsheets/d/1...1505794447
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
Great that we have CrOS support. Does it support OTA update?
Not yet.
Releases:
Buy me a Beer
Should we just unxz and then dd the image onto a MicroSD card? My initial attempt resulted in the PBP not booting and giving no visual feedback on the screen.
(10-02-2019, 04:38 AM)kunger Wrote: Should we just unxz and then dd the image onto a MicroSD card? My initial attempt resulted in the PBP not booting and giving no visual feedback on the screen.
You do not have UART by any chance do you? and yes, just dd the image.
I do. I'll work on getting that setup.
I know for a fact that it boots from eMMC ... but haven't been tested with the custom uboot that allows booting OVER the default build from SD
If you use other images it might mess with bootloader. It is advised to remove other medias before booting it.
Releases:
Buy me a Beer
You can also disable eMMC using a switch - reference wiki
Any guide how to enable Play Store?
Exclamation DONT INSTALL TO EMMC R77-12371.7.104.g78f88d6 VERSION YET! erchache2000 11 15,399 08-14-2020, 11:38 PM
Last Post: shoichimiyake
