Some PinePhone questions
(10-02-2019, 08:59 PM)Quddus Wrote: Hi,
I have a few questions about the PinePhone, I’m very excited by what I have seen so far!
Will the brave heart PinePhone be useable as a phone once the software is set up?
Does the PinePhone use microsd for storage? In which case I can buy an sd card with any capacity for more storage space?
I see that it has killswitches for the wifi, microphone, and so on. Are these external buttons or accessed through the UI?
What programming languages can be used to write programs for it’s available operating systems? Would it be the same as developing a desktop Linux application? Could you then use javascript/electron?
Thanks!
The "BaveHeart" release primary focus for early adopter, not normal daily user.
The microSD can be use as storage, we have tested up to 256GB card and should able to expend up to 2TB.
The killswitch locates inside phone, you needs to peel the back cover to access.
Some PinePhone questions - by Quddus - 10-02-2019, 08:59 PM
RE: Some PinePhone questions - by tllim - 10-03-2019, 09:48 PM
RE: Some PinePhone questions - by B2288 - 10-10-2019, 07:07 AM
  PinePhone Pro and PinePhone Community Edition Different SIM Card Trays dorkydev 2 280 04-11-2024, 03:10 PM
  Where PinePhone Pro are Made Tony90 1 576 01-18-2024, 09:20 AM
  using Zoom on Pinephone andrew907 5 1,225 12-09-2023, 01:26 AM
Last Post: crocspot
  pinephone 3 ideas aular 2 832 11-30-2023, 07:57 AM
Last Post: aular
  Star64 questions tantamount 3 1,444 05-20-2023, 10:18 AM
Last Post: tantamount
  Does pinephone allow you to repair your own device as easily as fairphone? unix21311 3 2,015 11-06-2022, 10:37 PM
Last Post: Harolddavies0
  can i install mobian on pinephone? luofeiyu 2 1,345 10-15-2022, 07:31 AM
Last Post: user641
  Does the pinephone have hardware kill switches located on the outside of the phone? unix21311 2 1,833 10-03-2022, 05:53 AM
Last Post: unix21311
Sad New PinePhone Mobian Weekly Image... No Boot photon 1 1,187 09-27-2022, 07:00 AM
Last Post: olyavi
  Questions JohnWMahaffey 1 1,223 04-24-2022, 04:09 PM
Last Post: Arwen
