Uses for SPI Flash
(09-30-2019, 10:25 AM)z4v4l Wrote: the SPI flash size of all pine boards is 128Mbits or 16MBs. it is intended for using as a firmware home, - uboot in this case, and not everything else. it's small for general usage, it wears out for frequent read/write cycles, and it gives you no advantage of having your cryptographic keys there. it is storage for firmware. there is nothing "unreliable " in it. this whole thread became a mess of confusions.
Computers were meant for number-crunching. The Internet was meant for research. But people did not listen ...
The supplied spi flash supports a min of 100,000 erase cycles per sector. Together with a flash filesystem which spread out writes, I can't imagine that the OP will ever wear out her flash.
Uses for SPI Flash - by NoraCodes - 09-29-2019, 10:53 AM
RE: Uses for SPI Flash - by Arwen - 09-29-2019, 11:38 AM
RE: Uses for SPI Flash - by NoraCodes - 09-29-2019, 01:12 PM
RE: Uses for SPI Flash - by Arwen - 09-29-2019, 07:53 PM
RE: Uses for SPI Flash - by kalpazanius - 09-30-2019, 03:28 AM
RE: Uses for SPI Flash - by ayufan - 09-30-2019, 04:47 AM
RE: Uses for SPI Flash - by kalpazanius - 10-01-2019, 06:14 AM
RE: Uses for SPI Flash - by danielt - 10-01-2019, 07:07 AM
RE: Uses for SPI Flash - by enip - 10-08-2019, 06:24 AM
RE: Uses for SPI Flash - by danielt - 10-08-2019, 09:41 AM
RE: Uses for SPI Flash - by kalpazanius - 10-08-2019, 09:53 AM
RE: Uses for SPI Flash - by danielt - 10-08-2019, 10:20 AM
RE: Uses for SPI Flash - by z4v4l - 09-30-2019, 10:25 AM
RE: Uses for SPI Flash - by Der Geist der Maschine - 09-30-2019, 10:57 AM
RE: Uses for SPI Flash - by z4v4l - 09-30-2019, 01:43 PM
RE: Uses for SPI Flash - by danielt - 10-01-2019, 05:42 AM
RE: Uses for SPI Flash - by danielt - 10-01-2019, 08:52 AM
RE: Uses for SPI Flash - by Arwen - 10-02-2019, 05:54 PM
RE: Uses for SPI Flash - by z4v4l - 10-02-2019, 08:30 PM
RE: Uses for SPI Flash - by danielt - 10-03-2019, 03:33 AM
RE: Uses for SPI Flash - by bcnaz - 10-04-2019, 03:02 AM
RE: Uses for SPI Flash - by PakoSt - 10-07-2019, 01:30 PM
RE: Uses for SPI Flash - by Arwen - 10-07-2019, 02:08 PM
RE: Uses for SPI Flash - by z4v4l - 10-07-2019, 02:52 PM
RE: Uses for SPI Flash - by bcnaz - 10-16-2019, 10:01 PM
RE: Uses for SPI Flash - by Arwen - 10-07-2019, 07:28 PM
RE: Uses for SPI Flash - by ayufan - 10-08-2019, 01:34 PM
RE: Uses for SPI Flash - by enip - 10-08-2019, 02:45 PM
RE: Uses for SPI Flash - by tsago - 10-09-2019, 09:51 AM
RE: Uses for SPI Flash - by z4v4l - 10-09-2019, 11:35 AM
RE: Uses for SPI Flash - by tsago - 10-10-2019, 04:48 AM
RE: Uses for SPI Flash - by enip - 10-10-2019, 09:09 AM
RE: Uses for SPI Flash - by z4v4l - 10-16-2019, 11:04 PM
RE: Uses for SPI Flash - by bcnaz - 10-21-2019, 06:29 PM
RE: Uses for SPI Flash - by z4v4l - 10-21-2019, 08:07 PM
  No boot after Manjaro flash PBcurry 14 5,746 10-03-2022, 08:33 PM
  U-Boot with direct NVMe boot support for eMMC/SPI Flash pcm720 125 217,879 09-27-2022, 07:41 AM
Last Post: olyavi
  How can I flash SPI so that I can boot from NVMe? codingpanic 5 6,036 08-24-2021, 05:07 AM
Last Post: codingpanic
Question erase spi flash aiminick 1 2,351 04-07-2021, 06:50 AM
  Booting to sdcard stopped working after emmc flash techiedog 3 4,020 12-31-2020, 06:30 PM
Last Post: Anarethos
  Flash non-bootable eMMC? midnightcheese 2 2,296 12-24-2020, 08:01 AM
Last Post: midnightcheese
  U-Boot on SPI flash - discussion Arwen 20 22,282 09-16-2020, 08:20 AM
Last Post: hmuller
  Am I supposed to flash keyboard firmware and u-boot imgs? superkazuya 4 5,916 09-02-2020, 04:12 AM
Last Post: pfeerick
  How to flash the emmc when it has Chromium on it? U47 3 4,498 07-10-2020, 10:07 AM
Last Post: U47
  emmc image will not flash Uturn 9 12,527 04-04-2020, 07:02 AM
Last Post: jiyong
