Rockpro64 and stock arch linux
(01-13-2020, 03:15 PM)Yoast Wrote:
(01-07-2020, 03:12 PM)dragop Wrote:
(01-02-2020, 09:25 AM)Yoast Wrote: @TaborFife, have you managed to get this working using an eMMC module instead of a SD card? I tried it, but it doesn't boot:
U-Boot TPL 2020.01-rc5-00042-g6cb87cbb14 (Jan 02 2020 - 15:30:57)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=15 CS=1 Die BW=16 Size=1024MB
Channel 1: LP
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to
U-Boot SPL 2020.01-rc5-00042-g6cb87cbb14 (Jan 02 2020 - 15:30:57 +0100)
Trying to boot from MMC2
unable to select a mode
mmc_load_image_raw_sector: mmc block read error
Trying to boot from MMmmc_load_image_raw_sector: mmc block read error
Trying to boot mmc_load_image_raw_sector: mmc block read error
SPL: failed to rd ###
FATAL: read from port failed: Device not configured
Hi, I'm able to boot from eMMC using the latest ROOTFS tarball. The latest kernel update seems to have nuked my setup though.
Good to know that it worked for you. Can you confirm the U-Boot version you are using? Is it also the 2020.01-rc5 version?
I cloned the master at the time. Since it booted right away, I didn't really try a proper release.
Rockpro64 and stock arch linux - by TaborFife - 09-21-2019, 04:29 PM
RE: Rockpro64 and stock arch linux - by Yoast - 11-29-2019, 12:18 PM
RE: Rockpro64 and stock arch linux - by Yoast - 01-02-2020, 09:25 AM
RE: Rockpro64 and stock arch linux - by dragop - 01-07-2020, 03:12 PM
RE: Rockpro64 and stock arch linux - by Yoast - 01-13-2020, 03:15 PM
RE: Rockpro64 and stock arch linux - by dragop - 01-15-2020, 05:17 PM
RE: Rockpro64 and stock arch linux - by abdel - 01-08-2020, 03:06 AM
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 536 03-25-2024, 12:12 PM
  yocto for RockPro64 Fide 1 747 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 2,676 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 867 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,618 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 83,946 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,351 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 610 05-21-2023, 11:34 PM
Last Post: shpark
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,039 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Rockpro64 Dead on arrival? quixoticgeek 1 979 03-12-2023, 06:55 PM
Last Post: quixoticgeek
