Pine HDMI -> DVI monitor
(09-05-2019, 01:46 PM)martinayotte Wrote:
(09-05-2019, 11:46 AM)Pineapple Wrote: Now I tried to put in the line and save but with no succes. Seems I have no permission? Huh
Do you mean you had problem saving the /boot/armbianEnv.txt ?
try it with "sudo nano /boot/armbianEnv.txt" ...
(09-05-2019, 07:43 PM)evilbunny Wrote:
(09-05-2019, 11:46 AM)Pineapple Wrote: Today reveiceed the HDMI to DVI adapter and hapily connected everything together and no signal..... Huh   Plugged the HDMI cable in my laptop and the old Monitor comes a live. So the adapter is working but somehow not with the Pine board.
I have trouble with a monitor or dvi adapter sending corrupt and/or blank edid and I have to force to work. On armbian I use:
extraargs=drm_kms_helper.edid_firmware=edid/1920x1080.bin
Thanks Martinayotte that worked Smile
Evilbunny tried that but that isn't working Sad
Tried your same line. But also put in the resolution of the screen which I am using ( Dell 1909WF 1440x900 ) and still not working.
When I discontect the cable screen says no cable connected. When I plug in the cable it goes straight into power saving mode.
This is what I got now in the file.
verbosity=1
overlay_prefix=rockchip
rootdev=UUID=e6f2ace3-a9fd-4cb6-a5f5-c69dec4583d4
rootfstype=ext4
disp_dvi_compat=1
extraargs=drm_kms_helper.edid_firmware=edid/1440x900.bin
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
edit... after I change something I did rebooted the Pine board. Smile
edit no 2... Seems it might be a DVI hot plug problem. Just measured Pin no.16 and there was no voltaged. Will try to solder a resistor in my screen this week to see if it will keep out of the sleep mode.
Source: http://philtechnicalblog.blogspot.com/20...ilema.html
Pine HDMI -> DVI monitor - by Pineapple - 09-05-2019, 11:46 AM
RE: Pine HDMI -> DVI monitor - by martinayotte - 09-05-2019, 01:46 PM
RE: Pine HDMI -> DVI monitor - by Pineapple - 09-09-2019, 12:26 PM
RE: Pine HDMI -> DVI monitor - by evilbunny - 09-05-2019, 07:43 PM
RE: Pine HDMI -> DVI monitor - by Pineapple - 09-10-2019, 11:28 AM
  pine store paulhide 1 3,256 09-17-2020, 04:13 AM
Last Post: bcnaz
  My optimal software configuration for pine A64(+) 2Gb Alkemyboy 3 4,711 03-18-2020, 08:41 AM
  First Boot HDMI/USB problem reefer 1 5,060 11-18-2018, 10:32 PM
  PINE A64+ 4K Media Computer RWL 4 6,960 11-08-2018, 04:20 PM
Last Post: mindwave
  Multi Room Audio - Pine style mjgoode 4 8,768 09-19-2018, 10:30 AM
Last Post: mjgoode
  Here Is another mini-how-to to install Raspbian:DESKTOP/ETHERNET/HDMI speedro86 4 8,284 04-15-2018, 07:37 AM
Last Post: bunkerWHz
  Pine 64 LTS Schematic And R18 Reference Manual Akash Gajjar 2 5,323 12-26-2017, 07:01 PM
  HDMI "Format not supported" sam452 3 6,649 06-11-2017, 10:38 AM
Last Post: Beta_Ravener
  RESOLVED - LCD screen not working, HDMI does asuras 10 16,137 04-02-2017, 08:12 AM
Last Post: Luke
  HDMI and LCD hienhuynh1982 19 25,501 03-23-2017, 10:16 PM
