Replace/Upgrade trackpad
Hi, I'm the owner of the original 14" Pinebook and the touchpad/trackpad is almost unusable for me :-( The surface is kind of rough, but either I have an faulty part or the overall quality is just horrible.
Sometimes as I slide my finger across the cursor stops or makes jumps, on the other hand the movement is so sensitive that I have big issues stopping at most of the UI elements, even big buttons. In other words - the cursor will not track the movement of my fingers properly but once set in motion it has some kind of weird inertia ... I didn't find any way yet to fix it on the software side. This behaviour happens on recent Armbian Buster with mainline Kernel
Anyhow, I have an old Synaptic touchpad form some notebook I bought on eBay for few bucks and the seller already soldered PS2 cable to it, so I can use it as a normal PS2 touchpad. I wonder if I could connect it to the Pinebook internally. PS2-USB adapter would be an option as well as long there is some internal USB connection in the Pinebook.
Replace/Upgrade trackpad - by tophneal - 05-31-2019, 11:09 AM
RE: Replace/Upgrade trackpad - by tllim - 06-07-2019, 01:24 AM
RE: Replace/Upgrade trackpad - by tophneal - 06-17-2019, 11:13 AM
RE: Replace/Upgrade trackpad - by bolinches - 11-13-2019, 01:57 PM
RE: Replace/Upgrade trackpad - by adoven1103 - 12-07-2019, 11:54 PM
RE: Replace/Upgrade trackpad - by jezek - 12-08-2019, 09:15 AM
RE: Replace/Upgrade trackpad - by karlitos - 01-10-2020, 02:30 AM
  pinebook to pro upgrade path? dhosh 13 18,479 11-14-2019, 11:25 AM
Last Post: bcnaz
  LCD Upgrade Lyga 14 20,552 07-30-2019, 09:59 PM
Last Post: binholz
  Trackpad research bbraun 0 1,759 11-25-2018, 03:00 PM
Last Post: bbraun
Bug Erratic Trackpad soupbowl 0 1,950 09-21-2018, 03:28 PM
Last Post: soupbowl
  RAM upgrade? frank-zappa 4 10,539 05-04-2018, 05:46 PM
Last Post: aproximation
  emmc upgrade Erik 1 3,398 10-23-2017, 08:17 AM
Last Post: erchache2000
  upgrade paths? schepers_cp 5 6,046 08-23-2017, 11:55 AM
Last Post: machinehum
  emmc upgrade eclay 3 5,146 06-26-2017, 05:47 PM
Last Post: zer0sig
