low speed wifi
(04-15-2019, 02:56 AM)pas059 Wrote: Hello,
Recently, i changed my internet connection to an optical fiber solution. For my internet connection, i use this wifi adapter bought with my rock64. I expected to get an important increase of the bandwidth, but the results are really bad; the maximum speed is: ~8 MBits for download, ~11MBits for upload althought my connections allows much more (on other computers i get at least 10 times more with wifi). I also tested this wifi adapter on a windows pc, and the performances are bad too.
Some one can explain this, or can recommand another usb2 wifi adapter?
regards
What image are you using?
Any errors in dmesg or syslog?
That wifi adaptor should do 10+MBytes/s
low speed wifi - by pas059 - 04-15-2019, 02:56 AM
RE: low speed wifi - by evilbunny - 04-15-2019, 03:24 AM
RE: low speed wifi - by pas059 - 04-15-2019, 04:25 AM
RE: low speed wifi - by pas059 - 05-10-2019, 09:52 AM
RE: low speed wifi - by pas059 - 05-13-2019, 12:09 PM
Heart Best quick/easy way to control case fan speed? idillicah 4 6,121 06-24-2021, 09:14 AM
Last Post: CounterPillow
  get wifi mt7601u mediatek usb dongle to work Johannes 0 2,480 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 11,371 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  RTL8192EU WIFI elik745i 12 25,115 05-13-2020, 05:03 PM
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 3,954 03-08-2019, 02:44 AM
Last Post: shripal17
Bug Fan speed controlled by CPU temp script mikedhoore 2 4,194 01-14-2019, 05:16 PM
Last Post: va88
  50 kb with RTL8188eu WIFI adapter Juice4 2 3,610 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 2,889 11-01-2018, 12:21 AM
Last Post: wsk
  Wifi; how to? scalextrix 12 17,224 05-30-2018, 12:20 AM
Last Post: scalextrix
  Network Speed stuartiannaylor 27 30,615 05-06-2018, 10:07 AM
Last Post: S3phi40T
