get wifi mt7601u mediatek usb dongle to work
Finally I got my usb wifi dongle working.
From linux kernel 4.xx on this chip is supported but I found out - after using several linux distributions - that it just doesn't work from the start.
Two patches are needed for the driver to get it to play.
First get the right kernel sources and headers for the linux distribution (kernel) you use.
In my case it was a 5.8.17 linux kernel (armbian 20.08.1). With 'apt ..' you can get the kernel sources, but command 'armbian-config' makes it easy to install them in /usr/src/ .
Note that a specific version number within the headers (see http://billauer.co.il/blog/2013/10/versi...obe-force/ ) should be exactly the same for the compiled driver.
In my case this was 5.8.17-rockchip64, but the installed headers contained only 5.8.17.
Update this so it is the same. (If you don't do that insmod fails.)
Then follow the 2 steps below:
1. php.c
follow this:
https://github.com/kuba-moo/mt7601u/issu...-352250127
2. mcu.c
follow this:
https://bbs.archlinux.org/viewtopic.php?id=224859
Command ifconfig should show a wifi device now.
'armbian-config' let you easily set the password and wifi access point for your wifi connection.
Regards,
Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 11,241 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  RTL8192EU WIFI elik745i 12 24,801 05-13-2020, 05:03 PM
  low speed wifi pas059 4 5,232 05-13-2019, 12:09 PM
Last Post: pas059
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 1,724 05-03-2019, 01:32 AM
Last Post: pcosm
  Using ESP32 as WiFi and Bluetooth Module shripal17 2 3,890 03-08-2019, 02:44 AM
Last Post: shripal17
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 1,754 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  50 kb with RTL8188eu WIFI adapter Juice4 2 3,544 11-09-2018, 12:56 PM
Last Post: Juice4
  WIFI driver compilation wsk 1 2,851 11-01-2018, 12:21 AM
Last Post: wsk
  Wifi; how to? scalextrix 12 16,961 05-30-2018, 12:20 AM
Last Post: scalextrix
  Very disappointed with ROCK64 USB WIFI 802.11B/G/N Danielsan 0 2,310 04-23-2018, 09:51 AM
Last Post: Danielsan
