New Builds from ayufan (0.8.X) w Video/3D/Mate desktop
#21
(04-25-2019, 12:55 PM)soerenderfor Wrote:
(04-21-2019, 08:02 AM)rhens1 Wrote:
(04-13-2019, 10:54 AM)Nerevarine Wrote: Any way to fix 0.8 build ? I can never log into desktop. its always stuck at black screen, even in rc9
I tried the rc9 and also got the black screen.  I then remotely logged into the router IP I had set for the Rock64 (4G).  I then used PUTTY  and a SSH tunnel.  The Rock64 had completed the boot and was running.  I then used a VNC remote after installing tightvncserver, my favorite.  The xstartup file under the .vnc folder has to be modified, but the Rock64 works well.  The best I can tell is that the black screen is caused by the inability to frequency sync with the display.  The programmers could fix this with a config.txt file where the monitor specs could be specified to sync.  I have done this on the RPi SBCs with ubuntu MATE to fill out my screen.  By all indications the Rock64 rc9 MATE version was trying to sync at 75 Hz and couldn't.  This is probably true of all the release candidates (RCs) for ubuntu MATE.
For anyone wanting the xstartup edit, it is below:
#!/bin/sh
xrdb $HOME/.Xresources
xsetroot -solid grey
#x-terminal-emulator -geometry 80x24+10+10 -ls -title "$VNCDESKTOP Desktop" &
#x-window-manager &
# Fix to make GNOME work
# export XKL_XMODMAP_DISABLE=1
# /etc/X11/Xsession
unset SESSION_MANAGER
unset DBUS_SESSION_BUS_ADDRESS
export XKB_DEFAULT_RULES=base
/usr/bin/mate-session
Your fix, can the ROCK64 then use 3D acc?
Sorry, this is not a fix, but a way to remotely have a desktop.  I don't think 3D acceleration would work in this case.  I just want people to have a way of seeing what is going on with the MATE desktop.  This desktop is way beyond the LXDE.  It is also beyond MATE on any RPi that I have.  Just seeing it in action should give the people here hope that the ROCK64 is NOT a dead end product.  You will have to wait until the GPU/monitor frequency sync problem is fixed before using the 3D acc.  BTW, the RPi 2, 3B and 3B+ also have a somewhat  similar problem, but have a table of monitor settings, pixel width, height and frequency in a (fat32 partition) config.txt file to force the GPU to sync and size.  T'aint elegant, but it works really well if you pick the correct settings Undecided
RE: New Builds from ayufan (0.8.X) w Video/3D/Mate desktop - by rhens1 - 04-25-2019, 03:41 PM
  How to Change Video Memory Amount gazhow64 0 738 12-10-2022, 04:12 PM
Last Post: gazhow64
  Ayufan LXDE with Teamviewer or Dwservice? cenicero 0 2,000 03-14-2020, 06:39 AM
Last Post: cenicero
  Remote desktop access Rock64 over Internet hg6806 2 3,968 12-11-2019, 08:27 PM
Last Post: default_user8
  Release 0.9.14 Ubuntu Mate desktop, LXDE, OMV, Docker CE (container) Luke 1 4,101 09-19-2019, 07:00 AM
Last Post: Malmgren
Star [archived] New Stable release from Ayufan (0.8.3) Luke 3 6,917 07-10-2019, 10:40 AM
Last Post: Malmgren
Star ayufan's 0.8.0rc12 (Rock64 Rev 3) Luke 1 3,321 06-13-2019, 02:05 AM
Last Post: pineadmin
  How fast is rock64 if a desktop? heocb 11 15,145 04-21-2019, 09:14 PM
Last Post: a1w.ca
  Video : Media Script for the Rock64/4K video in Linux NicoD 1 4,237 03-30-2019, 02:17 AM
Last Post: zet_lab
  Ayufan Debian Stretch Openmediavault 4 5G Wifi Not Connecting Poincare 0 2,281 03-26-2019, 07:28 PM
Last Post: Poincare
  ayufan 0.7.12 pre-release images (help testing) Luke 1 4,596 03-22-2019, 05:11 PM
Last Post: Luke
