Image for ZFS on PCIe SATA drives with OpenVPN and WiFi
TL;DR Which distro/image supports ZFS, PCIe SATA card, OpenVPN Client, and optionally WiFi?
I have finally received my RockPro64 4GB with the NAC case, eMMC module, PCIe card and WiFi module.
My goal is to build a remote backup server for important ZFS datasets on our home server.
The home server runs Ubuntu with ZFSonLinux.
Ideally, the backup server connects via WiFi and is configured through systemd. It will need to connect to the home server via OpenVPN.
To my questions:
1. Being completely new to Linux on ARM, I would appreciate some help with the choice of the distro/image to achieve my goal.
2. Which network manager would you then recommend to automatically connect to my OpenVPN server?
3. I forgot to buy the eMMC USB adapter. Is it feasible to boot from an SD card and then dd onto the eMMC?
I have read that WiFi and PCIe is not possible in parallel, so I made the WiFi requirement optional.
Image for ZFS on PCIe SATA drives with OpenVPN and WiFi - by caillou - 02-26-2019, 05:14 PM
  RK3399 PCIe enumeration jhadd 0 298 01-31-2024, 08:56 AM
Last Post: jhadd
Question nand-sata-install on RAID-1 array ARMandHammer 1 910 02-12-2023, 03:10 AM
Last Post: igorp
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,257 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 1,327 03-28-2022, 02:01 PM
Last Post: moserwi
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 1,055 02-17-2022, 12:10 PM
Last Post: flounder
  Debian image configured for USB-C OTG? djonathan 2 2,622 01-06-2022, 03:09 AM
Last Post: susy1075
  No PCIe controller detected... Limhes 1 1,621 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 1,861 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 1,422 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 6,903 05-20-2021, 10:04 PM
Last Post: t4_4t
