bullseye 11.3 WiFi drivers
Downloaded files from https://github.com/LibreELEC/brcmfmac_sdio-firmware
and placed them in /lib/firmware/brcm/
BCM4345C0.hcd
brcmfmac43455-sdio.bin
brcmfmac43455-sdio.pine64,rockpro64-v2.1.txt
brcmfmac43455-sdio.txt
dmesg |grep firm
[    0.000000] psci: PSCIv1.1 detected in firmware.
[  13.956292] platform regulatory.0: firmware: direct-loading firmware regulatory.db
[  13.976156] platform regulatory.0: firmware: direct-loading firmware regulatory.db.p7s
[  14.174721] brcmfmac mmc0:0001:1: firmware: direct-loading firmware brcm/brcmfmac43455-sdio.bin
[  14.174838] brcmfmac mmc0:0001:1: firmware: failed to load brcm/brcmfmac43455-sdio.pine64,rockpro64-v2.0.txt (-2)
[  14.175925] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
[  14.176891] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.pine64,rockpro64-v2.0.txt failed with error -2
[  14.256595] brcmfmac mmc0:0001:1: firmware: direct-loading firmware brcm/brcmfmac43455-sdio.txt
[  15.507776] bluetooth hci1: firmware: direct-loading firmware brcm/BCM4345C0.hcd
Well yes because brcmfmac43455-sdio.pine64,rockpro64-v2.1.txt  was renamed from brcmfmac43456-sdio.pine64,rockpro64-v2.1.txt
as I cound not locate the correct file.
checked armbian too but it looks like there is nothing applicable in /lib/firmware/brcm
Did anyone solve this problem?
location of the correct file? or maybe another way to implement the firmwre?
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 16,843 08-16-2023, 01:34 AM
Last Post: varac
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,322 02-19-2022, 06:44 AM
Last Post: sigmaris
  prevent bluetooth from loading (manjaro, no wifi/bt card installed) flounder 0 992 02-17-2022, 12:10 PM
Last Post: flounder
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 7,313 11-08-2021, 02:33 PM
Last Post: TRS-80
  WiFi not working with PCIe SSD installed mikeD 0 1,365 05-25-2021, 07:48 AM
Last Post: mikeD
  Wifi on Manjaro User 19517 0 1,850 09-14-2020, 06:53 PM
Last Post: User 19517
  RockPro64 Slow Ping on WiFi jl_678 0 1,845 05-14-2020, 05:08 PM
Last Post: jl_678
Information Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D Luke 100 124,516 10-04-2019, 08:57 PM
Last Post: tuxd3v
  Image for ZFS on PCIe SATA drives with OpenVPN and WiFi caillou 0 1,854 02-26-2019, 05:14 PM
Last Post: caillou
  How to install Mali drivers? tenspd137 0 1,698 02-11-2019, 09:57 PM
Last Post: tenspd137
