Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment
(06-16-2019, 01:19 PM)tuxd3v Wrote: If you look into my current temperature:
' Current Temperature (C): 26'
You will notice that its **a lot lower** than in your disks, ( your luck is that you own Seagate disks...they support higher temps than others.. maxout at 70C, for the case.. )
If I recall it correctly your higher temp are around 50C, that starts to be uncomfortable high..
Mines maxout at around ~30C ..
Hello tuxd3v,
I also thought about why the temperature is so high. My second hard drive (4TB) also has a high temperature about 32c in sleep mode, in operation I try to cool it with fan always. (no comparison to your 26c). what does it relate to?????????
(06-16-2019, 01:19 PM)tuxd3v Wrote: I have:
# for blockid in {a..d};do smartctl --attributes /dev/sd${blockid}|grep -E "^ 12|^193"; done
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       4
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1898
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1874
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1852
My Load/Unload numbers are like new ( ~ 1800 cycles.. )  Shy
My Load/Unload numbers is too high? ( ~ 5400 cycles.. )  Angry ???
root@p-ubuntu:~/openSeaChest/Make/gcc/openseachest_exes# for blockid in {a..d};do smartctl --attributes /dev/sd${blockid}|grep -E "^ 12|^193"; done
12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       3124
12 Power_Cycle_Count       0x0032   094   094   000    Old_age   Always       -       5485
(06-16-2019, 01:19 PM)tuxd3v Wrote: And then instead of using '/dev/sda' use '/dev/sg0'( probably this will not work, because even using '/dev/sda' Seagate uses underneath the SCSI protocol over ATA.. its only a shot.. ).
no difference, have already tried that post #9
(06-16-2019, 01:19 PM)tuxd3v Wrote: Your problem, probably has to do with the fact that, your Sata Adapter, doesn't Acknowledge the power cycle you do when rebooting the Operating system..
Try configuring , then shutting down, remove the disk, wait a bit insert it again, and then boot and check..
If that doesn't work, you probably need a native Sata port around..  Sad
most likely, I'm looking for a desktop PC. my last chance. I do not understand the problem, why developer (Seagate) can not make that easier.
Thank you for your help and patience with me!
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 10,010 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,403 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 53,431 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,267 10-23-2020, 11:56 AM
Last Post: hmuller
Thumbs Up Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities tuxd3v 41 76,488 04-08-2019, 10:10 AM
Last Post: Neo2018
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,746 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 3,989 11-06-2018, 01:03 PM
Last Post: tuxd3v
