Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities
Thumbs Up
Hello All,
I saw that some users have Seagate IronWolfs disks paired with RockPro64..
There are some features that, are nice to configure on Seagate Disks..
Seagate has tools for disks..
Tools that are Present in the OpenSeaChest Utilities:
  • openSeaChest_Basics
  • openSeaChest_Configure
  • openSeaChest_Erase
  • openSeaChest_Firmware
  • openSeaChest_Format
  • openSeaChest_GenericTests
  • openSeaChest_Info
  • openSeaChest_Logs
  • openSeaChest_NVMe
  • openSeaChest_PowerControl
  • openSeaChest_SMART
Here is the Documentation:   Seagate SeaChest Utilities
The Repository is here: OpenSeaChest Utilities
You will need to compile OpenSeaChest Utilities, as root:
1) Jump to /root
cd /root
2) Use last Stable Release( v19.01.31 - Released 6 days ago, by xahmad )
git clone --recursive --branch v19.01.31 https://github.com/Seagate/openSeaChest.git
3) Jump into OpenSeaChest gcc compilation method and Compile the project:
    OBS: I tried using parallel compilation and it failed, better to use 1 process only like bellow..
cd openSeaChest/Make/gcc && make release
4) Wait for compilation to Finish, and check if there are erros at the end.
    If there are no errors, then copy binaries to final destination and remove code stuff used to compile:
mkdir -pv /opt/openSeaChest/bin && mv openseachest_exes/* /opt/openSeaChest/bin cd / && rm -rf /root/openSeaChest
5) Update your root PATH environment var to know about OpenSeachest Utilities:
cat <<<'export PATH="${PATH}:/opt/openSeaChest/bin"' >> /root/.bashrc
6) Exit from root and log again has root,
exit && sudo su -
7) Now try to see if root, knows about OpenSeachest Utilities:
    type "open" and press <TAB>, you will see at least :
                           openSeaChest_FormatUnit    openSeaChest_PowerControl openSeaChest_Basics        openSeaChest_GenericTests  openSeaChest_SMART openSeaChest_Configure     openSeaChest_Info          openSeaChest_ZBD openSeaChest_Erase         openSeaChest_Logs           openSeaChest_Firmware      openSeaChest_NVMe
8) Now has a Candy, check information about your Disk, using openSeaChest_Basics:
# openSeaChest_Basics --deviceInfo --device /dev/sdX ========================================================================================== openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Basics Version: 2.8.0-1_19_0 ARM Build Date: Feb  3 2019 Today: Wed Feb  6 12:56:52 2019 ========================================================================================== /dev/sg0 - ST4000VN008-XXXXXX - XXXXXXXX - ATA Model Number: ST4000VN008-XXXXXX Serial Number: XXXXXXXX Firmware Revision: SC60 World Wide Name: XXXXXXXXXXXXXXXX Drive Capacity (TB/TiB): 4.00/3.64 Native Drive Capacity (TB/TiB): 4.00/3.64 Temperature Data: Current Temperature (C): 16 Highest Temperature (C): 27 Lowest Temperature (C): 13 Power On Time:  4 days 6 hours 59 minutes Power On Hours: 102.98 MaxLBA: 7814037167 Native MaxLBA: 7814037167 Logical Sector Size (B): 512 Physical Sector Size (B): 4096 Sector Alignment: 0 Rotation Rate (RPM): 5980 Form Factor (inch): 3.5 Last DST information: DST has never been run Long Drive Self Test Time:  10 hours 13 minutes Interface speed: Max Speed (Gb/s): 6.0 Negotiated Speed (Gb/s): 6.0 Annualized Workload Rate (TB/yr): 341.03 Total Bytes Read (TB): 4.01 Total Bytes Written (MB): 24.24 Encryption Support: Not Supported Cache Size (MiB): 64.00 Read Look-Ahead: Enabled Write Cache: Enabled Low Current Spinup: Enabled SMART Status: Good ATA Security Information: Supported Firmware Download Support: Full, Segmented, Deferred, DMA Specifications Supported: ACS-3 ACS-2 ATA8-ACS ATA/ATAPI-7 ATA/ATAPI-6 ATA/ATAPI-5 ATA/ATAPI-4 SATA 3.1 SATA 3.0 SATA 2.6 SATA 2.5 SATA II: Extensions SATA 1.0a ATA8-AST Features Supported: Sanitize SATA NCQ SATA Rebuild Assist SATA Software Settings Preservation [Enabled] SATA Device Initiated Power Management HPA Power Management Security SMART [Enabled] DCO 48bit Address PUIS [Enabled] APM [Enabled] GPL Streaming SMART Self-Test SMART Error Logging Write-Read-Verify Sense Data Reporting [Enabled] SCT Write Same SCT Error Recovery Control SCT Feature Control SCT Data Tables Host Logging Seagate In Drive Diagnostics (IDD)
OBS: Read Carefully the Documentation about OpenSeachest Utilities, to not damage your data, or your disk..
          Start by openSeaChest_Basics tool, which seems less prone, to problems.. in the time you are aquiring the needed skills..
Hope you Enjoy.. [Image: thumbsup.png]
Regards
Appreciate and thanks on the tutorial.
(02-06-2019, 07:53 PM)tllim Wrote: Appreciate and thanks on the tutorial.
Hello tllim,
You welcome   Shy
(02-06-2019, 07:05 AM)tuxd3v Wrote: 8) Now has a Candy, check information about your Disk, using openSeaChest_Basics:
Hello tuxd3v, I need your help again please
I have decided to install OpenSeachest.
So far my actions are:
cd /root git clone --recursive --branch v19.01.31 https://github.com/Seagate/openSeaChest.git cd openSeaChest/Make/gcc && make release
after the make release command as far as I can see, there are no errors. Last lines after make release command >
../../utils/C/openSeaChest/openSeaChest_NVMe.c:74:5: note: in expansion of macro 'PARTIAL_DATA_ERASE_VAR'     PARTIAL_DATA_ERASE_VAR     ^~~~~~~~~~~~~~~~~~~~~~ ../../utils/C/openSeaChest/openSeaChest_NVMe.c:1134:34: warning: 'fullSize' may be used uninitialized in this function [-Wmaybe-uninitialized]                             while(offset < fullSize)                                  ^ cc ../../utils/C/openSeaChest/openSeaChest_NVMe.o ../../src/EULA.o ../../src/openseachest_util_options.o -Wall ../../opensea-operations/Make/gcc/lib/libopensea-operations.a ../../opensea-transport/Make/gcc/lib/libopensea-transport.a ../../opensea-common/Make/gcc/lib/libopensea-common.a -lm -lrt -o openseachest_exes/openSeaChest_NVMe cc -Wall -c -std=gnu99 -O3 -I../../opensea-common/include -I../../opensea-transport/include -I../../include -I../../opensea-operations/include -DDISABLE_TCG_SUPPORT ../../utils/C/openSeaChest/openSeaChest_Logs.c -o ../../utils/C/openSeaChest/openSeaChest_Logs.o cc ../../utils/C/openSeaChest/openSeaChest_Logs.o ../../src/EULA.o ../../src/openseachest_util_options.o -Wall ../../opensea-operations/Make/gcc/lib/libopensea-operations.a ../../opensea-transport/Make/gcc/lib/libopensea-transport.a ../../opensea-common/Make/gcc/lib/libopensea-common.a -lm -lrt -o openseachest_exes/openSeaChest_Logs
Before I put it to copying and the binaries to the final destination, I first wanted to test it.
(02-06-2019, 07:05 AM)tuxd3v Wrote: 7) Now try to see if root, knows about OpenSeachest Utilities:
Try with the command >
cd /root/openSeaChest/Make/gcc/openseachest_exes ls openSeaChest_Basics     openSeaChest_Firmware      openSeaChest_Info  openSeaChest_PowerControl openSeaChest_Configure  openSeaChest_FormatUnit    openSeaChest_Logs  openSeaChest_SMART openSeaChest_Erase      openSeaChest_GenericTests  openSeaChest_NVMe  openSeaChest_ZBD type "open" and press <TAB>
No function
openSeaChest_Basics -bash: openSeaChest_Basics: command not found  openSeaChest_Info -bash: openSeaChest_Info: command not found
What's wrong, how do I test the functions?
Many Thanks!
Sad
(02-28-2019, 02:02 PM)Neo2018 Wrote: I have decided to install OpenSeachest.
No function
Many Thanks!
Hello Neo2018,
No problem [Image: wink.png]
Because you don't have binaries in final destination and maybe not in the PATH Environment Variable yet, you cannot execute them as if the system knows were they are..
You need to execute, or with absolute paths, or relative to the folder they are:
A example of openSeaChest_Basics options '-h' switch, to see possibilities of the tool:
1) Absolute paths:
/root/openSeaChest/Make/gcc/openseachest_exes/openSeaChest_Basics -h
2) Relative paths:
cd /root/openSeaChest/Make/gcc/openseachest_exes ./openSeaChest_Basics -h
In your case, that you want to see information about the disks( X is your drive letter, a,b,c,d and so on.. ):
1) Absolute paths:
/root/openSeaChest/Make/gcc/openseachest_exes/openSeaChest_Basics --deviceInfo --device /dev/sdX
2) Relative paths:
cd /root/openSeaChest/Make/gcc/openseachest_exes ./openSeaChest_Basics --deviceInfo --device /dev/sdX
In this way, you can use all tools, but its boring since you can follow steps 4,5,6.. and after that you can purely issue the command you want too
Drop me a line, how it were going [Image: shy.png]
(03-01-2019, 10:40 AM)tuxd3v Wrote: In your case, that you want to see information about the disks( X is your drive letter, a,b,c,d and so on.. ):
1) Absolute paths:
2) Relative paths:
Hey, thanks for your answer
I was too stupid last night, did not even come up with the idea to do it with ./openSeaChest_Basics. Sorry Blush
but unfortunately that does not work properly>  /root/openSeaChest/Make/gcc/openseachest_exes/openSeaChest_Basics --deviceInfo --device /dev/sdb > output >
/root/openSeaChest/Make/gcc/openseachest_exes/openSeaChest_Basics --deviceInfo --device /dev/sdb ========================================================================================== openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Basics Version: 2.8.0-1_19_0 ARM Build Date: Feb 28 2019 Today: Fri Mar  1 18:18:46 2019 ========================================================================================== open: Bad address open failure Error: 14 - Bad address Error: Could not open handle to /dev/sdb
my hard drives >
:~# df -h Filesystem      Size  Used Avail Use% Mounted on udev            1.9G     0  1.9G   0% /dev tmpfs           388M   40M  348M  11% /run /dev/mmcblk1p7   57G  8.8G   46G  17% / tmpfs           1.9G  8.0K  1.9G   1% /dev/shm tmpfs           5.0M  8.0K  5.0M   1% /run/lock tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup tmpfs           1.9G   36K  1.9G   1% /tmp /dev/mmcblk1p6  112M   10K  112M   1% /boot/efi /dev/sda1       458G  266G  193G  58% /srv/dev-disk-by-label-Daten2 /dev/sdb1       3.6T  2.3T  1.4T  64% /srv/dev-disk-by-label-Daten folder2ram      1.9G  499M  1.5G  26% /var/log folder2ram      1.9G     0  1.9G   0% /var/tmp folder2ram      1.9G  724K  1.9G   1% /var/lib/openmediavault/rrd folder2ram      1.9G  1.6M  1.9G   1% /var/spool folder2ram      1.9G   16M  1.9G   1% /var/lib/rrdcached folder2ram      1.9G   12K  1.9G   1% /var/lib/monit folder2ram      1.9G  4.0K  1.9G   1% /var/lib/php folder2ram      1.9G  4.0K  1.9G   1% /var/lib/netatalk/CNID folder2ram      1.9G  524K  1.9G   1% /var/cache/samba overlay          57G  8.8G   46G  17% /var/lib/docker/overlay2/915c4ad2cc7d3cde1e6bede0bf6fccd152a371fe96a1dc7b3c388486136dc2db/merged overlay          57G  8.8G   46G  17% /var/lib/docker/overlay2/926760e4cc0d73f08bc8d1c9acffad1b88c77f116812f790d4e29403509b9ca4/merged overlay          57G  8.8G   46G  17% /var/lib/docker/overlay2/f5093a63511d249a8c80d8752f60ddc4fb166944dac056b354adf853053d8c5d/merged shm              64M     0   64M   0% /var/lib/docker/containers/db1a35c9e6185adf6e04a220da21a23d1ecaf5dabb19e9600938c4fcfcef0490/mounts/shm shm              64M     0   64M   0% /var/lib/docker/containers/e41de1c0c35a1dccf993ee58f88e610f910506bbc7526aa6b6a285b99a74bc0e/mounts/shm shm              64M     0   64M   0% /var/lib/docker/containers/04dc60abbb2bab37469103288fb74ba2e0d119ec9a74bc31e0771221c9c853f9/mounts/shm overlay          57G  8.8G   46G  17% /var/lib/docker/overlay2/82205090b3380be4d858d032a57cd65e99143ad7f6c56ea72710d77dddcc6283/merged shm              64M     0   64M   0% /var/lib/docker/containers/99caab121e27b07f61b49427783d880f3f8f9349f9b98807dec560a5f427c699/mounts/shm tmpfs           388M     0  388M   0% /run/user/0
That's why I wanted to test that first.
I try that with  >
Quote:In this way, you can use all tools, but its boring since you can follow steps 4,5,6.. and after that you can purely issue the command you want too
(03-01-2019, 10:40 AM)tuxd3v Wrote: In this way, you can use all tools, but its boring since you can follow steps 4,5,6.. and after that you can purely issue the command you want too
It does not work...
Quote:7) Now try to see if root, knows about OpenSeachest Utilities:
No Answer....
Quote:4) Wait for compilation to Finish, and check if there are erros at the end.
The folder has now been deleted > cd / && rm -rf /root/openSeaChest ......... I now need everything from new download and > cd openSeaChest/Make/gcc && make release > re-execute?
:/opt/openSeaChest/bin# ls -la total 8640 drwxr-xr-x 2 root root   4096 Mar  1 19:25 . drwxr-xr-x 3 root root   4096 Mar  1 19:25 .. -rwxr-xr-x 1 root root 747660 Feb 28 19:53 openSeaChest_Basics -rwxr-xr-x 1 root root 733056 Feb 28 19:53 openSeaChest_Configure -rwxr-xr-x 1 root root 737828 Feb 28 19:53 openSeaChest_Erase -rwxr-xr-x 1 root root 636864 Feb 28 19:56 openSeaChest_Firmware -rwxr-xr-x 1 root root 729564 Feb 28 19:56 openSeaChest_FormatUnit -rwxr-xr-x 1 root root 752088 Feb 28 19:53 openSeaChest_GenericTests -rwxr-xr-x 1 root root 824812 Feb 28 19:56 openSeaChest_Info -rwxr-xr-x 1 root root 700332 Feb 28 19:56 openSeaChest_Logs -rwxr-xr-x 1 root root 739004 Feb 28 19:56 openSeaChest_NVMe -rwxr-xr-x 1 root root 743072 Feb 28 19:53 openSeaChest_PowerControl -rwxr-xr-x 1 root root 741984 Feb 28 19:53 openSeaChest_SMART -rwxr-xr-x 1 root root 725144 Feb 28 19:56 openSeaChest_ZBD
(03-01-2019, 11:48 AM)Neo2018 Wrote: The folder has now been deleted > cd / && rm -rf /root/openSeaChest ......... I now need everything from new download and > cd openSeaChest/Make/gcc && make release > re-execute?
No, You now have the binaries in final destination.. [Image: shy.png]
you need this:
# grep openSeaChes /root/.bashrc --color export PATH="${PATH}:/opt/openSeaChest/bin"
or you can also do it for your session with:
Then type 'open' + <TAB>
In the error you report..."wrong channel", that its strange, could be anny special char in the between..
when you do
lsblk
What appears in your NAS box?
(03-01-2019, 04:56 PM)tuxd3v Wrote: or you can also do it for your session with:
Ok that works now.
:~# open openSeaChest_Basics        openSeaChest_FormatUnit    openSeaChest_NVMe          openssl openSeaChest_Configure     openSeaChest_GenericTests  openSeaChest_PowerControl  openvpn openSeaChest_Erase         openSeaChest_Info          openSeaChest_SMART openSeaChest_Firmware      openSeaChest_Logs          openSeaChest_ZBD
But >
:~# openSeaChest_Basics --deviceInfo --device /dev/sdb ========================================================================================== openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Basics Version: 2.8.0-1_19_0 ARM Build Date: Feb 28 2019 Today: Sat Mar  2 11:38:54 2019 ========================================================================================== open: Bad address open failure Error: 14 - Bad address Error: Could not open handle to /dev/sdb
Error ! ? Why, how so?
Quote:In the error you report..."wrong channel", that its strange, could be anny special char in the between..
when you do
lsblk
:~# lsblk NAME         MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT sda            8:0    0 465.8G  0 disk `-sda1         8:1    0 465.8G  0 part /srv/dev-disk-by-label-Daten2 sdb            8:16   0   3.7T  0 disk `-sdb1         8:17   0   3.7T  0 part /srv/dev-disk-by-label-Daten mtdblock0     31:0    0     4M  0 disk mtdblock1     31:1    0    32K  0 disk mtdblock2     31:2    0   256K  0 disk mmcblk1      179:0    0  57.6G  0 disk |-mmcblk1p1  179:1    0   3.9M  0 part |-mmcblk1p2  179:2    0    64K  0 part |-mmcblk1p3  179:3    0     4M  0 part |-mmcblk1p4  179:4    0     4M  0 part |-mmcblk1p5  179:5    0     4M  0 part |-mmcblk1p6  179:6    0   112M  0 part /boot/efi `-mmcblk1p7  179:7    0  57.5G  0 part / mmcblk1boot0 179:32   0     4M  1 disk mmcblk1boot1 179:64   0     4M  1 disk mmcblk1rpmb  179:96   0     4M  0 disk
Where is the mistake?
Hello Neo2018,
It could be a hidden character called 'special characters'..or it could be something else..
Run this command, to see if it detect the disks..
openSeaChest_Basics --scan
Please, the part that says:
'Model Number' - Substitute last content after '-' by 'XXXXXX'
'Serial Number'  - Substitute all by 'XXXXXXXX'
After that,
Paste output...it could be related to the pcie-controller, and this could be helpful, not only to you, but also to other users [Image: wink.png]
(03-02-2019, 11:06 AM)tuxd3v Wrote: It could be a hidden character called 'special characters'..or it could be something else..
:~# openSeaChest_Basics --scan ========================================================================================== openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved openSeaChest_Basics Version: 2.8.0-1_19_0 ARM Build Date: Feb 28 2019 Today: Sat Mar  2 18:13:39 2019 ========================================================================================== open: Bad address open failure Error: 14 - Bad address open: Bad address open failure Error: 14 - Bad address
(03-02-2019, 11:06 AM)tuxd3v Wrote: Please, the part that says:
After that,
IN OMV WEB/GUI INTERFACE
[Image: 2RXMK.jpg]
smartctl 6.6 2016-05-31 r4324 [aarch64-linux-4.4.154-1132-rockchip-ayufan-g8260cd865508] (local build) Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family:     Seagate IronWolf Device Model:     ST4000VN008-2DR166 Serial Number:    ZDH36NNE LU WWN Device Id: 5 000c50 0afc5c4f5 Firmware Version: SC60 User Capacity:    4,000,787,030,016 bytes [4.00 TB] Sector Sizes:     512 bytes logical, 4096 bytes physical Rotation Rate:    5980 rpm Form Factor:      3.5 inches Device is:        In smartctl database [for details use: -P show] ATA Version is:   ACS-3 T13/2161-D revision 5 SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s) Local Time is:    Sat Mar  2 18:28:35 2019 CET SMART support is: Available - device has SMART capability. SMART support is: Enabled AAM feature is:   Unavailable APM level is:     254 (maximum performance) Rd look-ahead is: Enabled Write cache is:   Disabled ATA Security is:  Disabled, NOT FROZEN [SEC1] Wt Cache Reorder: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status:  (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status:      (   0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: (  591) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities:            (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability:        (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: (   1) minutes. Extended self-test routine recommended polling time: ( 636) minutes. Conveyance self-test routine recommended polling time: (   2) minutes. SCT capabilities:       (0x50bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE  1 Raw_Read_Error_Rate     POSR--   080   064   044    -    100551871  3 Spin_Up_Time            PO----   094   094   000    -    0  4 Start_Stop_Count        -O--CK   085   085   020    -    15686  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0  7 Seek_Error_Rate         POSR--   088   060   045    -    631875942  9 Power_On_Hours          -O--CK   091   091   000    -    8453 (229 242 0) 10 Spin_Retry_Count        PO--C-   100   100   097    -    0 12 Power_Cycle_Count       -O--CK   100   100   020    -    37 184 End-to-End_Error        -O--CK   100   100   099    -    0 187 Reported_Uncorrect      -O--CK   100   100   000    -    0 188 Command_Timeout         -O--CK   100   100   000    -    0 189 High_Fly_Writes         -O-RCK   100   100   000    -    0 190 Airflow_Temperature_Cel -O---K   062   053   040    -    38 (Min/Max 24/41) 191 G-Sense_Error_Rate      -O--CK   100   100   000    -    0 192 Power-Off_Retract_Count -O--CK   090   090   000    -    21292 193 Load_Cycle_Count        -O--CK   082   082   000    -    37230 194 Temperature_Celsius     -O---K   038   047   000    -    38 (0 21 0 0 0) 197 Current_Pending_Sector  -O--C-   100   100   000    -    0 198 Offline_Uncorrectable   ----C-   100   100   000    -    0 199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    1 240 Head_Flying_Hours       ------   100   253   000    -    3346 (16 125 0) 241 Total_LBAs_Written      ------   100   253   000    -    12977159047 242 Total_LBAs_Read         ------   100   253   000    -    38338985213                            ||||||_ K auto-keep                            |||||__ C event count                            ||||___ R error rate                            |||____ S speed/performance                            ||_____ O updated online                            |______ P prefailure warning General Purpose Log Directory Version 1 SMART           Log Directory Version 1 [multi-sector log support] Address    Access  R/W   Size  Description 0x00       GPL,SL  R/O      1  Log Directory 0x01           SL  R/O      1  Summary SMART error log 0x02           SL  R/O      5  Comprehensive SMART error log 0x03       GPL     R/O      5  Ext. Comprehensive SMART error log 0x04       GPL,SL  R/O      8  Device Statistics log 0x06           SL  R/O      1  SMART self-test log 0x07       GPL     R/O      1  Extended self-test log 0x09           SL  R/W      1  Selective self-test log 0x10       GPL     R/O      1  SATA NCQ Queued Error log 0x11       GPL     R/O      1  SATA Phy Event Counters log 0x13       GPL     R/O      1  SATA NCQ Send and Receive log 0x15       GPL     R/W      1  SATA Rebuild Assist log 0x21       GPL     R/O      1  Write stream error log 0x22       GPL     R/O      1  Read stream error log 0x24       GPL     R/O    512  Current Device Internal Status Data log 0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log 0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log 0xa1       GPL,SL  VS      24  Device vendor specific log 0xa2       GPL     VS    8160  Device vendor specific log 0xa6       GPL     VS     192  Device vendor specific log 0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log 0xab       GPL     VS       1  Device vendor specific log 0xb0       GPL     VS    9048  Device vendor specific log 0xbe-0xbf  GPL     VS   65535  Device vendor specific log 0xc1       GPL,SL  VS      16  Device vendor specific log 0xd1       GPL     VS     136  Device vendor specific log 0xd2       GPL     VS   10000  Device vendor specific log 0xd3       GPL     VS    1920  Device vendor specific log 0xe0       GPL,SL  R/W      1  SCT Command/Status 0xe1       GPL,SL  R/W      1  SCT Data Transfer SMART Extended Comprehensive Error Log Version: 1 (5 sectors) No Errors Logged SMART Extended Self-test Log Version: 1 (1 sectors) Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error # 1  Short offline       Completed without error       00%      8296         - # 2  Short offline       Completed without error       00%      8296         - # 3  Short offline       Completed without error       00%      6965         - # 4  Short offline       Completed without error       00%      6368         - # 5  Short offline       Completed without error       00%      6367         - # 6  Short offline       Completed without error       00%      6366         - # 7  Short offline       Completed without error       00%      6365         - # 8  Short offline       Completed without error       00%      6364         - # 9  Short offline       Completed without error       00%      6363         - #10  Short offline       Completed without error       00%      6362         - #11  Short offline       Completed without error       00%      6361         - #12  Short offline       Completed without error       00%      6360         - #13  Short offline       Completed without error       00%      6359         - #14  Short offline       Completed without error       00%      6358         - #15  Short offline       Completed without error       00%      6357         - #16  Short offline       Completed without error       00%      6356         - #17  Short offline       Completed without error       00%      6356         - #18  Short offline       Completed without error       00%      6354         - #19  Short offline       Completed without error       00%      6353         - SMART Selective self-test log data structure revision number 1 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS    1        0        0  Not_testing    2        0        0  Not_testing    3        0        0  Not_testing    4        0        0  Not_testing    5        0        0  Not_testing Selective self-test flags (0x0):  After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay. SCT Status Version:                  3 SCT Version (vendor specific):       522 (0x020a) SCT Support Level:                   1 Device State:                        Active (0) Current Temperature:                    37 Celsius Power Cycle Min/Max Temperature:     24/42 Celsius Lifetime    Min/Max Temperature:     21/47 Celsius Under/Over Temperature Limit Count:   0/53 SCT Temperature History Version:     2 Temperature Sampling Period:         3 minutes Temperature Logging Interval:        59 minutes Min/Max recommended Temperature:      0/ 0 Celsius Min/Max Temperature Limit:            0/ 0 Celsius Temperature History Size (Index):    128 (56) Index    Estimated Time   Temperature Celsius  57    2019-02-25 13:17    32  *************  58    2019-02-25 14:16    33  **************  59    2019-02-25 15:15    32  ************* ...    ..(  4 skipped).    ..  *************  64    2019-02-25 20:10    32  *************  65    2019-02-25 21:09    31  ************  66    2019-02-25 22:08    33  **************  67    2019-02-25 23:07    33  **************  68    2019-02-26 00:06    39  ********************  69    2019-02-26 01:05    42  ***********************  70    2019-02-26 02:04    36  *****************  71    2019-02-26 03:03    33  **************  72    2019-02-26 04:02    34  ***************  73    2019-02-26 05:01    35  **************** ...    ..(  4 skipped).    ..  ****************  78    2019-02-26 09:56    35  ****************  79    2019-02-26 10:55    36  *****************  80    2019-02-26 11:54    35  ****************  81    2019-02-26 12:53    34  ***************  82    2019-02-26 13:52    34  ***************  83    2019-02-26 14:51    34  ***************  84    2019-02-26 15:50    35  ****************  85    2019-02-26 16:49    35  ****************  86    2019-02-26 17:48    34  ***************  87    2019-02-26 18:47    36  *****************  88    2019-02-26 19:46    35  ****************  89    2019-02-26 20:45    35  ****************  90    2019-02-26 21:44    34  ***************  91    2019-02-26 22:43    33  **************  92    2019-02-26 23:42    41  **********************  93    2019-02-27 00:41    40  *********************  94    2019-02-27 01:40    38  *******************  95    2019-02-27 02:39    34  ***************  96    2019-02-27 03:38    33  **************  97    2019-02-27 04:37    33  **************  98    2019-02-27 05:36    33  **************  99    2019-02-27 06:35    32  ************* ...    ..(  2 skipped).    ..  ************* 102    2019-02-27 09:32    32  ************* 103    2019-02-27 10:31    31  ************ 104    2019-02-27 11:30    33  ************** 105    2019-02-27 12:29    33  ************** 106    2019-02-27 13:28    33  ************** 107    2019-02-27 14:27    34  *************** 108    2019-02-27 15:26    35  **************** 109    2019-02-27 16:25    34  *************** 110    2019-02-27 17:24    34  *************** 111    2019-02-27 18:23    33  ************** 112    2019-02-27 19:22    33  ************** 113    2019-02-27 20:21    34  *************** 114    2019-02-27 21:20    35  **************** 115    2019-02-27 22:19    34  *************** 116    2019-02-27 23:18    33  ************** 117    2019-02-28 00:17    37  ****************** 118    2019-02-28 01:16    33  ************** 119    2019-02-28 02:15    33  ************** 120    2019-02-28 03:14    32  ************* ...    ..(  5 skipped).    ..  ************* 126    2019-02-28 09:08    32  ************* 127    2019-02-28 10:07    39  ********************   0    2019-02-28 11:06    41  **********************   1    2019-02-28 12:05    41  **********************   2    2019-02-28 13:04    41  **********************   3    2019-02-28 14:03     ?  -   4    2019-02-28 15:02    24  *****   5    2019-02-28 16:01    32  *************   6    2019-02-28 17:00    32  *************   7    2019-02-28 17:59    32  *************   8    2019-02-28 18:58    31  ************   9    2019-02-28 19:57    33  **************  10    2019-02-28 20:56    38  *******************  11    2019-02-28 21:55    30  ***********  12    2019-02-28 22:54    34  ***************  13    2019-02-28 23:53    38  *******************  14    2019-03-01 00:52    31  ************  15    2019-03-01 01:51    35  ****************  16    2019-03-01 02:50    36  *****************  17    2019-03-01 03:49    36  *****************  18    2019-03-01 04:48    38  *******************  19    2019-03-01 05:47    34  ***************  20    2019-03-01 06:46    33  **************  21    2019-03-01 07:45    33  **************  22    2019-03-01 08:44    40  *********************  23    2019-03-01 09:43    33  **************  24    2019-03-01 10:42    40  *********************  25    2019-03-01 11:41    41  **********************  26    2019-03-01 12:40    30  ***********  27    2019-03-01 13:39    31  ************  28    2019-03-01 14:38    32  *************  29    2019-03-01 15:37    31  ************  30    2019-03-01 16:36    32  *************  31    2019-03-01 17:35    31  ************  32    2019-03-01 18:34    37  ******************  33    2019-03-01 19:33    39  ********************  34    2019-03-01 20:32    36  *****************  35    2019-03-01 21:31    32  *************  36    2019-03-01 22:30    32  *************  37    2019-03-01 23:29    32  *************  38    2019-03-02 00:28    33  **************  39    2019-03-02 01:27    32  *************  40    2019-03-02 02:26    33  **************  41    2019-03-02 03:25    35  ****************  42    2019-03-02 04:24    33  **************  43    2019-03-02 05:23    32  ************* ...    ..(  2 skipped).    ..  *************  46    2019-03-02 08:20    32  *************  47    2019-03-02 09:19    31  ************  48    2019-03-02 10:18    31  ************  49    2019-03-02 11:17    30  ***********  50    2019-03-02 12:16    38  *******************  51    2019-03-02 13:15    32  *************  52    2019-03-02 14:14    32  *************  53    2019-03-02 15:13    34  ***************  54    2019-03-02 16:12    34  ***************  55    2019-03-02 17:11    35  ****************  56    2019-03-02 18:10    34  *************** SCT Error Recovery Control:           Read:     70 (7.0 seconds)          Write:     70 (7.0 seconds) Device Statistics (GP Log 0x04) Page  Offset Size        Value Flags Description 0x01  =====  =               =  ===  == General Statistics (rev 1) == 0x01  0x008  4              37  ---  Lifetime Power-On Resets 0x01  0x010  4            8453  ---  Power-on Hours 0x01  0x018  6     12977158894  ---  Logical Sectors Written 0x01  0x020  6        52184450  ---  Number of Write Commands 0x01  0x028  6     38338972784  ---  Logical Sectors Read 0x01  0x030  6       268830280  ---  Number of Read Commands 0x01  0x038  6               -  ---  Date and Time TimeStamp 0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) == 0x03  0x008  4      2280457129  N--  Spindle Motor Power-on Hours 0x03  0x010  4      2280457043  N--  Head Flying Hours 0x03  0x018  4           37230  ---  Head Load Events 0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors 0x03  0x028  4               0  ---  Read Recovery Attempts 0x03  0x030  4               0  ---  Number of Mechanical Start Failures 0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors 0x03  0x040  4           21293  ---  Number of High Priority Unload Events 0x04  =====  =               =  ===  == General Errors Statistics (rev 1) == 0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors 0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion 0x05  =====  =               =  ===  == Temperature Statistics (rev 1) == 0x05  0x008  1              37  ---  Current Temperature 0x05  0x010  1              33  ---  Average Short Term Temperature 0x05  0x018  1              32  ---  Average Long Term Temperature 0x05  0x020  1              47  ---  Highest Temperature 0x05  0x028  1               0  ---  Lowest Temperature 0x05  0x030  1              43  ---  Highest Average Short Term Temperature 0x05  0x038  1              22  ---  Lowest Average Short Term Temperature 0x05  0x040  1              37  ---  Highest Average Long Term Temperature 0x05  0x048  1              28  ---  Lowest Average Long Term Temperature 0x05  0x050  4               0  ---  Time in Over-Temperature 0x05  0x058  1              70  ---  Specified Maximum Operating Temperature 0x05  0x060  4               0  ---  Time in Under-Temperature 0x05  0x068  1               0  ---  Specified Minimum Operating Temperature 0x06  =====  =               =  ===  == Transport Statistics (rev 1) == 0x06  0x008  4           12711  ---  Number of Hardware Resets 0x06  0x010  4           12599  ---  Number of ASR Events 0x06  0x018  4               1  ---  Number of Interface CRC Errors                                |||_ C monitored condition met                                ||__ D supports DSN                                |___ N normalized value SATA Phy Event Counters (GP Log 0x11) ID      Size     Value  Description 0x000a  2            9  Device-to-host register FISes sent due to a COMRESET 0x0001  2            0  Command failed due to ICRC error 0x0003  2            0  R_ERR response for device-to-host data FIS 0x0004  2            0  R_ERR response for host-to-device data FIS 0x0006  2            0  R_ERR response for device-to-host non-data FIS 0x0007  2            0  R_ERR response for host-to-device non-data FIS
[Image: 2RXNC.jpg][Image: 2RXND.jpg]
please tell me the console / terminal commands, for more output
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 27,359 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 9,071 01-17-2021, 11:33 AM
  Tutorial:How to Configure ATS Fan control tuxd3v 26 83,728 11-06-2020, 08:56 PM
Last Post: g_t_j
  Serial Connection Tutorial: FTDI 232RL hmuller 0 8,363 10-23-2020, 11:56 AM
Last Post: hmuller
Video How to Install Google PlayStore NightCrawler504 2 9,357 04-08-2020, 02:20 PM
Last Post: pino88
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 43,111 06-19-2019, 04:40 AM
Last Post: Neo2018
Video Video and Guide to install Android to emmc no emmc to usb adapter NightCrawler504 0 5,258 04-21-2019, 07:19 PM
Last Post: NightCrawler504
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 5,279 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 5,998 11-06-2018, 01:03 PM
Last Post: tuxd3v
  HOW TO - install linux on emmc without etcher or USB adapter dukla2000 4 16,084 07-31-2018, 12:40 PM
Last Post: dukla2000
