Humm, Hold on a bit... I will check Documentation..
There are a Feature to turn changes persistent, it works for only a subset of things, maybe I forgot that..
I will look into it, and you can try it then..
What a moment ..
EDIT:
For what I saw you already have:
'SATA Software Settings Preservation [Enabled]'
But I detected that you have some things that I don't, and I have another ones that you don't..
With a power on time of:
' Power On Time: 134 days 13 hours 57 minutes'
I have:
My Load/Unload numbers are like new ( ~ 1800 cycles.. )
If you look into my current temperature:
' Current Temperature (C): 26'
You will notice that its **a lot lower** than in your disks, ( your luck is that you own Seagate disks...they support higher temps than others.. maxout at 70C, for the case.. )
If I recall it correctly your higher temp are around 50C, that starts to be uncomfortable high..
Mines maxout at around ~30C ..
I Remember of one thing..
Try to set values with the ISCSI handler instead:
Identify the handler:
And then instead of using '/dev/sda' use '/dev/sg0'( probably this will not work, because even using '/dev/sda' Seagate uses underneath the SCSI protocol over ATA.. its only a shot.. ).
Your problem, probably has to do with the fact that, your Sata Adapter, doesn't Acknowledge the power cycle you do when rebooting the Operating system..
Try configuring , then shutting down, remove the disk, wait a bit insert it again, and then boot and check..
If that doesn't work, you probably need a native Sata port around..
What a moment ..
EDIT:
root@helios4:~# openSeaChest_Basics --deviceInfo --device /dev/sda -v 1
openSeaChest_Basics - openSeaChest drive utilities - NVMe Enabled
Copyright (c) 2014-2018 Seagate Technology LLC and/or its Affiliates, All Rights Reserved
openSeaChest_Basics Version: 2.8.0-1_19_0 ARM
Build Date: Feb 3 2019
Today: Sun Jun 16 19:47:51 2019
/dev/sg0 - ST4000VN008-XXXXXX - XXXXXXXX - ATA
Model Number: ST4000VN008-XXXXXX
Serial Number: XXXXXXXX
Firmware Revision: SC60
World Wide Name: xyzw
Drive Capacity (TB/TiB): 4.00/3.64
Native Drive Capacity (TB/TiB): 4.00/3.64
Temperature Data:
Highest Temperature (C): 39
Lowest Temperature (C): 0
Power On Hours: 3229.95
MaxLBA: 7814037167
Native MaxLBA: 7814037167
Logical Sector Size (B): 512
Physical Sector Size (B): 4096
Sector Alignment: 0
Rotation Rate (RPM): 5980
Form Factor (inch): 3.5
Last DST information:
DST has never been run
Long Drive Self Test Time: 10 hours 13 minutes
Interface speed:
Max Speed (Gb/s): 6.0
Negotiated Speed (Gb/s): 6.0
Annualized Workload Rate (TB/yr): 66.98
Total Bytes Read (TB): 20.15
Total Bytes Written (TB): 4.55
Encryption Support: Not Supported
Cache Size (MiB): 64.00
Read Look-Ahead: Enabled
Write Cache: Enabled
Low Current Spinup: Enabled
SMART Status: Good
ATA Security Information: Supported
Firmware Download Support: Full, Segmented, Deferred, DMA
Specifications Supported:
ACS-3
ACS-2
ATA8-ACS
ATA/ATAPI-7
ATA/ATAPI-6
ATA/ATAPI-5
ATA/ATAPI-4
SATA 3.1
SATA 3.0
SATA 2.6
SATA 2.5
SATA II: Extensions
SATA 1.0a
ATA8-AST
Features Supported:
Sanitize
SATA NCQ
SATA Rebuild Assist
SATA Device Initiated Power Management
HPA
Power Management
Security
SMART [Enabled]
DCO
48bit Address
PUIS [Enabled]
APM [Enabled]
GPL
Streaming
SMART Self-Test
SMART Error Logging
Write-Read-Verify
Sense Data Reporting [Enabled]
SCT Write Same
SCT Error Recovery Control
SCT Feature Control
SCT Data Tables
Host Logging
Seagate In Drive Diagnostics (IDD)
I have:
# for blockid in {a..d};do smartctl --attributes /dev/sd${blockid}|grep -E "^ 12|^193"; done
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 4
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1898
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1874
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1852
openSeaChest_Basics --scan --scanFlags sgtosd --device /dev/sda
Today: Sun Jun 16 20:28:29 2019
Vendor Handle Model Number Serial Number FwRev
ATA sg0<->sda ST4000VN008-XXXXXX XXXXXXXX SC60
ATA sg1<->sdb ST4000VN008-XXXXXX XXXXXXXX SC60
ATA sg2<->sdc ST4000VN008-XXXXXX XXXXXXXX SC60
