Does the Pine usb to sata adapter work with hd-parm?
Hi!
I have a Rock64 with OMV, this sata to usb adapter and a WD red . My issue is that the adapter spins down the hard drive after 10 minutes of inactivity and there seems to be no way to increase that duration. I tried the integrated hd-parm in OMV and hd-idle with no luck. Thus, I need to change the adapter.
My questions are:
  1. Does the adapter sold by pine support hd-parm?
  2. Are there any dual sata adapters that work with hd-parm or have a higher spindown time?
  3. Is there a way to have al least 2 hard drives attached to the usb3 port in a reliable way? I noticed that on the OMV forums they advice against using usb hubs.
Thanks!
Does the Pine usb to sata adapter work with hd-parm? - by FabrizioMaurizio - 02-06-2019, 11:37 AM
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,076 04-26-2023, 11:38 PM
  USB3 SATA ReleaseTheGeese 2 2,779 04-04-2021, 12:55 PM
Last Post: ReleaseTheGeese
  get wifi mt7601u mediatek usb dongle to work Johannes 0 2,452 11-17-2020, 09:48 AM
Last Post: Johannes
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 11,258 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
  USB3 to SATA cable - Firmware Eule 0 2,195 03-03-2020, 01:31 PM
Last Post: Eule
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 6,136 05-04-2019, 04:19 AM
Last Post: burito111
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 1,735 05-03-2019, 01:32 AM
Last Post: pcosm
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 3,762 12-01-2018, 03:53 AM
Last Post: jovval
  50 kb with RTL8188eu WIFI adapter Juice4 2 3,554 11-09-2018, 12:56 PM
Last Post: Juice4
  usb 3 gigabit ethernet adapter frewind 2 3,684 09-24-2018, 10:01 AM
Last Post: frewind
