Pine64 (analog) Audio Jack Output w/ Kernel 4.19
Hi, this is a question about Kernel 4.19 and Analog Audio Jack Output on Pine64 Original (old) board.
For the Kernel 3.10, I've found a thread stating that the following modules can make the Audio Jack works:
https://forum.pine64.org/showthread.php?tid=807
[ modules - Kernel 3.10 ]
sunxi_codec
sunxi_i2s
sunxi_sndcodec
I am trying Armbiam with Kernel 4.19 and want to ask what are the modules that I need to have in order to make the Analog Audio Jack work?
The following are the default modules for current Armbiam (5.70):
[ lsmod - Armbiam 5.70, Kernel 4.19 ]
Module                  Size  Used by
fuse                   94208  3
overlay                90112  1
zstd                   16384  4
sun50i_codec_analog    24576  1
snd_soc_simple_card    16384  3
snd_soc_hdmi_codec     16384  1
snd_soc_spdif_tx       16384  0
sun8i_adda_pr_regmap    16384  1 sun50i_codec_analog
sun4i_i2s              24576  4
snd_soc_simple_card_utils    16384  1 snd_soc_simple_card
sun8i_codec            24576  1
axp20x_ac_power        16384  0
axp20x_battery         16384  0
snd_soc_core          126976  7 sun4i_i2s,snd_soc_spdif_tx,snd_soc_hdmi_codec,sun50i_codec_analog,sun8i_codec,snd_soc_simple_card_utils,snd_soc_simple_card
snd_pcm_dmaengine      16384  1 snd_soc_core
snd_pcm                90112  5 sun4i_i2s,snd_soc_hdmi_codec,sun8i_codec,snd_soc_core,snd_pcm_dmaengine
axp20x_adc             20480  0
snd_timer              32768  1 snd_pcm
sun4i_gpadc_iio        24576  0
snd                    57344  10 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
soundcore              16384  1 snd
industrialio           53248  4 axp20x_battery,sun4i_gpadc_iio,axp20x_ac_power,axp20x_adc
cpufreq_dt             16384  0
thermal_sys            65536  2 cpufreq_dt,sun4i_gpadc_iio
ip6t_REJECT            16384  1
zram                   24576  5
nf_reject_ipv6         16384  1 ip6t_REJECT
nf_log_ipv6            16384  6
xt_hl                  16384  22
ip6t_rt                16384  3
ipt_REJECT             16384  1
nf_reject_ipv4         16384  1 ipt_REJECT
nf_log_ipv4            16384  6
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  12
xt_multiport           16384  2
xt_limit               16384  15
xt_addrtype            16384  4
xt_conntrack           16384  12
ip6table_filter        16384  1
ip6_tables             28672  53 ip6table_filter
nf_conntrack_netbios_ns    16384  0
nf_conntrack_broadcast    16384  1 nf_conntrack_netbios_ns
nf_nat_ftp             16384  0
nf_nat                 28672  1 nf_nat_ftp
nf_conntrack_ftp       16384  1 nf_nat_ftp
nf_conntrack          110592  6 xt_conntrack,nf_nat,nf_nat_ftp,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_conntrack_ftp
nf_defrag_ipv6         20480  1 nf_conntrack
nf_defrag_ipv4         16384  1 nf_conntrack
iptable_filter         16384  1
pinctrl_axp209         16384  0
lima                   49152  0
dw_hdmi_cec            16384  0
dw_hdmi_i2s_audio      16384  0
gpu_sched              20480  1 lima
ttm                    86016  1 lima
realtek                20480  1
I have tested with a 3 connectors headphone and also with a 4 connector headset... both fail...
Also, when I plug a USB to Audio (CM108) Adapter, everything works fine, so, the issue seems to be around the Audio Jack itself...
Does anybody have the Audio Jack working with Kernel 4.19 (Armbian)?
If so, what are the procedures/setup that works?
Basically, I just want audio output from the Jack, mic input, in my case is not needed...
Thanks all,
Valter Fukuoka
Pine64 (analog) Audio Jack Output w/ Kernel 4.19 - by ecolezen - 01-24-2019, 07:00 AM
  Pine64 Suddenly Turnoff with Lcd mix359 4 10,309 07-08-2021, 08:50 AM
Last Post: e-minguez
  +LTS/SOPINE Audio Jack Pinout Little_Johnny 0 3,050 12-29-2019, 08:44 AM
Last Post: Little_Johnny
  PINE64 STEREO AUDIO DAC POT jtgiroux 0 3,217 01-12-2019, 04:56 PM
Last Post: jtgiroux
  Does Pine64+ have an internal hardware watchdog ? rahlquist 8 15,320 04-26-2018, 06:27 PM
Last Post: pfeerick
  Sound quality from audio jack devanl 0 3,327 10-11-2017, 10:39 PM
Last Post: devanl
  Audio Extractor Ralck 1 4,551 05-25-2017, 12:25 PM
Last Post: dkryder
Sad Enable Mic on 3.5 jack port saro 14 37,626 03-29-2017, 02:06 AM
Last Post: saro
  Using the pine64 with AVR - HDMI pass-through Moshe.Vazan 4 6,237 01-02-2017, 02:58 PM
Last Post: Moshe.Vazan
  Use Audiojack instead of HDMI audio pictus 55 129,799 12-24-2016, 06:03 PM
Last Post: Akiva
  I dropped my Pine64 DukeJustice 17 20,533 11-07-2016, 07:23 PM
Last Post: DukeJustice
