USB drive powered off after reboot
I've got an SSD connected to my rock64 via USB3 and booting from it without issues.
$ lsusb
Bus 005 Device 002: ID 7825:a2a4
The only problem is when I reboot the system. The USB is powering off, but won't get powered on again. As a result the system won't boot. Checked on latest bionic-minimal, stretch-minimal, openmediavault, dietpi. When I boot from the sdcard the drive gets powered on at first and running fine. Then again after reboot the USB is powered off and system boots from sdcard with the USB drive powered off.
An older HDD doesn't have this issue and power is delivered to the USB after reboot so looks like problems with this specific enclosure.
Run a test on RPI3 and after reboot the drive gets powered on.
Do you have some ideas what I could look for / test to nail it down?
Thank you
USB drive powered off after reboot - by huberttrz - 12-20-2018, 11:34 AM
  External hard drive problem k8Va 17 22,634 03-09-2021, 02:31 PM
Last Post: calinb
Sad Rock64 crash randomly during usb 3 copy with RAID1 drive phalae 24 35,350 09-14-2020, 10:48 AM
Last Post: BrownLuther007
  USB 3.0 hard drive write speed increase tip on Ubuntu 18.04 Wizardknight 3 6,911 05-26-2019, 10:28 PM
Last Post: Wizardknight
Question HDD filesystem corruption at reboot / poweroff (DietPi) WrongWorld 1 2,932 02-11-2019, 04:00 PM
Last Post: WrongWorld
  Spontaneous Reboot during scp with Ubuntu bionic 0.7.8-1061 perniciouscaffeine 0 1,895 10-16-2018, 05:34 PM
Last Post: perniciouscaffeine
  Freeze/reboot/errors when compiling - unable to make - reproducible and not isolated jovval 2 3,905 10-02-2018, 08:10 AM
Last Post: jovval
  Rock64 - Stuck when do the soft reboot ramprasad 10 13,888 06-21-2018, 01:16 AM
Last Post: pfeerick
  HDD gets not detected after reboot pascal51882 8 8,871 04-19-2018, 04:12 PM
Last Post: k8Va
  boot emmc, trying to access SD Drive E.G 0 1,632 04-13-2018, 09:05 PM
Last Post: E.G
  Root FS on usb3 drive eloranta 7 7,267 12-18-2017, 10:43 PM
Last Post: eloranta
