12-24-2018, 08:04 PM
(12-19-2018, 06:12 AM)kishanpatel Wrote: Hello,
Actually i am using rockpro64(rk3399) board. I have flashed bionoc-ubuntu-64bit image.
UI can see "mppvideodec" plugins when execute "gst-inspect-1.0 |grep mpp" command.
But, when i tried to use "mmpvideodec" in gstreamer,k i got some errors as below:
Setting pipeline to PAUSED ...
mpi: mpp version: Without VCS, under bleeding
Pipeline is live and does not need PREROLL ...
Got context from element 'autovideosink0': gst.gl.GLDisplay=context, gst.gl.GLDisplay=(GstGLDisplay)"\(GstGLDisplayX11\)\ gldisplayx11-0";
Setting pipeline to PLAYING ...
New clock: GstSystemClock
hal_h264d_api: Assertion p_hal->vcodec_type & ((0x00000200) | (0x00000001) | (0x00000002)) failed at hal_h264d_init:186
mpp_device: mpp_device_init failed to find device for coding 0 type 7
hal_h264d_api: p_hal->vpu_socket <= 0
mpp_hal: mpp_hal_init hal h264d_rkdec init failed ret -2
mpp_hal: mpp_hal_init could not found coding type 7
mpp_dec: mpp_dec_init could not init hal
mpp: error found on mpp initialization
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
Execution ended after 0:00:00.349876884
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
I have tried pipeline as below:
1. gst-launch-1.0 v4l2src device=/dev/video0 ! mppvideodec ! autovideosink
2. gst-launch-1.0 -v rtspsrc location=rtsp://admin:jenex#2018@192.168.1.108:554 latency=10 ! rtph264depay ! h264parse ! mppvideodec ! videoconvert ! autovideosink sync=false
Moreover, what is the meaning of "none" in below output:
rock64@rockpro64:~$ apt-cache policy linux-rock64-package
linux-rock64-package:
Installed: (none)
Candidate: 0.7-24
Version table:
0.7-24 500
500 http://deb.ayufan.eu/orgs/ayufan-rock64/releases Packages
0.6.44 500
0.5.15 500
0.5.10 500
0.5.9 500
0.5.8 500
0.4.17 500
0.4.16 500
0.4.12 500
0.4.3 500
0.3.7 500
0.3.4 500
0.3.3 500
0.3.2 500
0.2.1 500
Thanks & Regards,
Kishan Patel.
You can get to Linux-Rockchip freenode IRC and ping "ayaka", he is deep knowladge of Rockchip MPP and also involve on GStreamer.
