Rock64 Gstreamer
Hey,
Currently whenever i try to modify anything about my current pipeline apart from directly outputting it it crashes. The crash happens with things like using Videomixer, textoverlay or whenever i try to decode jpegs.
this is my current pipeline (eddited out some info from the url, it works) that works, any edits within it crashes.
gst-launch-1.0 rtspsrc location=rtsp://@192.168.178.40:554/ latency=0 ! decodebin  ! input-selector ! videoconvert ! rkximagesink
0:00:01.360255974  5931   0x7f6c083630 ERROR           rkximagesink ximagesink.c:566:gst_x_image_sink_ximage_put:<rkximagesink0> drmPrimeFDToHandle failed: Operation not permitted (-1)
0:00:01.406619723  5931   0x7f6c083630 ERROR       mppdecbufferpool gstmppdecbufferpool.c:203:gst_mpp_dec_buffer_pool_release_buffer:<mppvideodec0:poolConfusedrc> can't release an invalid buffer
this is the usual type of error i receive.
Are there any fix to this?
** (gst-launch-1.0:1910): CRITICAL **: 10:47:06.103: gst_dmabuf_memory_get_fd: assertion 'gst_is_dmabuf_memory (mem)' failed
This is another error i frequently receive with those other 2
(05-07-2019, 04:48 AM)Umkaia Wrote: ** (gst-launch-1.0:1910): CRITICAL **: 10:47:06.103: gst_dmabuf_memory_get_fd: assertion 'gst_is_dmabuf_memory (mem)' failed
For gsteamer implementation, you can explore with ayaka at Linux-Rockchip IRC.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 150 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,354 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 334 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 613 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 608 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,361 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,416 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 591 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 650 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,318 12-07-2022, 08:22 PM
Last Post: luminosity7
