Tutorial:How to Configure ATS Fan control
#20
(02-06-2019, 07:27 AM)tuxd3v Wrote: I noticed that you are using Seagate IronWolf disks..
Those cat handle a max temp of 70C, WesternDigital max out at 60C..
I also have IronWolfs in my setup..
I made a tutorial that you will need for Seagate disks:
https://forum.pine64.org/showthread.php?tid=7137
Thanks for the tip, good job again!
But I'm a bit scared to install an external tool now. Data loss.
I use OMV with S.M.A.R.T. for the HDD.
[Image: 2R3Yf.jpg]
Are you of the opinion that the tool is a good extension and with S.M.A.R.T. compatible?
RE: Tutorial:How to Configure ATS Fan control - by Neo2018 - 02-06-2019, 03:13 PM
  SkiffOS server with Docker ,NAS, Home assistant, Jellyfin, Snikket XMPP (tutorial) GreyLinux 12 10,085 04-04-2022, 05:26 AM
Last Post: GreyLinux
  SimpNas server with docker - home assistant, radicale , jellyfin & esphome (tutorial) GreyLinux 0 4,414 01-17-2021, 11:33 AM
  Serial Connection Tutorial: FTDI 232RL hmuller 0 3,283 10-23-2020, 11:56 AM
Last Post: hmuller
Wink Tutorial[ Seagate Disks ]: Optimize Life Span/Power Managment tuxd3v 14 24,320 06-19-2019, 04:40 AM
Last Post: Neo2018
Thumbs Up Tutorial[ Seagate Disks ]: Install Seagate OpenSeaChest Utilities tuxd3v 41 76,645 04-08-2019, 10:10 AM
Last Post: Neo2018
  Tutorial[ Multimedia ] : Play DVD movies tuxd3v 0 2,755 02-26-2019, 07:21 PM
Last Post: tuxd3v
  Tutorial[ OpenCL ]: OpenCL 1.2 FULL_PROFILE Working tuxd3v 0 3,995 11-06-2018, 01:03 PM
Last Post: tuxd3v
