I2S Codec on Euler bus of Pine A64+
Hi, Thanks for the reply. the dtb file used in arbmian image is sun50iw1pi-pine64-plus.dtb. and the noticeable difference is as below
sound@1 {
compatible = "allwinner,sunxi-daudio0-machine";
sunxi,daudio0-controller = <0x4e>;
status = "disabled";
device_type = "snddaudio0";
I have changed the staus to "okay" and also changed the "CONFIG_SND_SOC_DAUDIO0_MACHINE=m" in the config file. With the
change I could see the kernel module sunxi-snddaudio0.ko in the /lib/modules/3.10.107-pine64/kernel/sound/soc/sunxi
However the module is not loaded.
Then I manually tried to load by calling "insmod" which returns the following errors.
De 3 11:18:00 localhost kernel: [ 982.711898] snddaudio0 sound.8: ASoC: CPU DAI (null) not registered
Dec 3 11:18:00 localhost kernel: [ 982.711953] snddaudio0 sound.8: snd_soc_register_card() failed: -517
Dec 3 11:18:00 localhost kernel: [ 982.711898] snddaudio0 sound.8: ASoC: CPU DAI (null) not registered
Dec 3 11:18:00 localhost kernel: [ 982.711991] platform sound.8: Driver snddaudio0 requests probe deferral
As I understand certain dependency driver need to be install as well. Could you please help what else need to be enabled in configure file during kernel build?
the kernel version in the armbian build environment is 3.10.107
Any help will be highly apricated.
Regards
Ranjit
RE: I2S Codec on Euler bus of Pine A64+ - by RANJITT76 - 12-03-2018, 05:25 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 1,694 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 642 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 4,050 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 6,053 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 3,393 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 4,552 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 7,875 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 2,802 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 3,270 12-02-2019, 09:36 PM
Last Post: netHolio
  NetBSD for Pine A64(+) Luke 3 6,808 10-05-2019, 11:04 PM
Last Post: mrgtwentythree
