Power supply clarification
Quick Charge requires negotiation over data pins, but the Type H connector has none, so it will only provide up to the USB standard maximum of 500mA until it completes negotiation for more.  You can confirm your pinebook is charging at 300-500mA in this state by checking sysfs -- it's only enough to drain the battery more slowly, not charge it.
So to use the USB-to-H wire, you actually need a "dumb" power supply like the provided wall wart that just drives 3A without caring what's on the other end.  I know some power supplies meant for SBCs like RPi are like this, but I couldn't tell you how to be sure it's a dumb supply when browsing online, except that Quick Charge or any similar standard is a red flag.
Power supply clarification - by maldus - 11-28-2018, 08:13 AM
RE: Power supply clarification - by Luke - 11-28-2018, 09:07 AM
RE: Power supply clarification - by maldus - 12-10-2018, 01:44 PM
RE: Power supply clarification - by Luke - 12-12-2018, 11:26 AM
RE: Power supply clarification - by meredith - 12-16-2018, 08:01 PM
RE: Power supply clarification - by maldus - 12-17-2018, 03:55 AM
  pinebook 1080p power/barrel connector/cable cel 0 581 08-03-2023, 11:43 AM
Last Post: cel
  Disable auto power on? cel 0 2,638 12-22-2019, 08:41 AM
Last Post: cel
  Add separate power button? maddmike 2 3,543 12-17-2018, 04:35 PM
Last Post: maddmike
  Power LED / Charging LED Question d97 4 5,283 11-21-2018, 10:26 AM
Last Post: Noxmiles
  UK Power Adapter? dejan 5 6,778 12-06-2017, 04:44 PM
Last Post: DigitalStefan
  Internal power connector problem stealthbanana 1 3,015 09-19-2017, 10:45 AM
Last Post: MarkHaysHarris777
  noise random green pixel when plugged power supply only (solved. see edit.) BatteryDie 5 6,742 09-06-2017, 04:17 PM
Last Post: BatteryDie
Question Power Related Problem Questions p3p1 1 2,582 08-29-2017, 06:06 PM
  Wanted: Better power adapter for Pinebook. flingtoad 4 6,463 08-21-2017, 10:09 PM
Last Post: Siliconserf
Thumbs Down Power Supply Design Flaw Siliconserf 11 12,392 08-15-2017, 12:26 PM
