Power LED / Charging LED Question
Hi - I've noticed what I think is somewhat unusual behaviour in my 14 inch Pinebook.  When I plug the adapter in, the orange charging light doesn't light up to let me know that the machine is charging - at least not until I've done a couple of things.
When the machine is shut down and I plug the adapter in, I get no orange led.
When I open the pinebook up, I get a brief flash of what looks like a battery charging icon but the LED stay unlit.
When I start the pinebook, the LED lights up orange and stays lit after I shut the machine down - until it is fully charged and the LED goes off.
Is this normal?  Has anybody else experienced this?
D.
(09-03-2017, 09:06 AM)d97 Wrote: Hi - I've noticed what I think is somewhat unusual behaviour in my 14 inch Pinebook.  When I plug the adapter in, the orange charging light doesn't light up to let me know that the machine is charging - at least not until I've done a couple of things.
D.
Yes this is typical behavior.
Good to know! Thanks for the reply - I appreciate the time!
D.
Hi all,
Would it be possible for Pinebook v1.1 to switch places between power-plug and charge led.
Then the charger cable will not block the charge led.  Smile
thx
//Fred
Does the battery charge, when the Pinebook is shut down and the power-plug is inserted then? (No light = no charching?)
  pinebook 1080p power/barrel connector/cable cel 0 542 08-03-2023, 11:43 AM
Last Post: cel
  Disable auto power on? cel 0 2,601 12-22-2019, 08:41 AM
Last Post: cel
Question Pinebook Spares - Screen question soupbowl 3 4,535 01-12-2019, 02:57 PM
Last Post: soupbowl
  Add separate power button? maddmike 2 3,486 12-17-2018, 04:35 PM
Last Post: maddmike
  Power supply clarification maldus 5 6,084 12-17-2018, 03:55 AM
Last Post: maldus
  UK Power Adapter? dejan 5 6,643 12-06-2017, 04:44 PM
Last Post: DigitalStefan
  Internal power connector problem stealthbanana 1 2,965 09-19-2017, 10:45 AM
Last Post: MarkHaysHarris777
  noise random green pixel when plugged power supply only (solved. see edit.) BatteryDie 5 6,620 09-06-2017, 04:17 PM
Last Post: BatteryDie
Question Power Related Problem Questions p3p1 1 2,539 08-29-2017, 06:06 PM
  Wanted: Better power adapter for Pinebook. flingtoad 4 6,350 08-21-2017, 10:09 PM
Last Post: Siliconserf
