How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI
If I remember correctly, if you just always install the -dev version of everything, it also installs the non-dev pieces too, but 'apt' won't mark the non-dev package as 'installed' if you do that.
I'm not 100% sure if all -dev packages work that way.
I set my system up the hard way - I installed the libs at first and then later installed the -dev versions whenever the compile would fail.
None of the packages are really consistent about naming conventions and whatnot.
For several libs, I had to remove the version number, and append -dev, and sometimes I had to ADD the version number.
Sometimes I had to add the minor version too, or the version number was separated by a dash first, when it wasn't using a dash in the non-dev version.
Stuff like that.
It almost never worked when I just appended "-dev" to the already installed non-dev version of the package.
Had to keep 'apt search'ing because I'm not that bright.
( Within the next 1-3 weeks, I'm going to format AGAIN with ubuntu minimal and do the entire deployment again, and THIS time I will write down the entire stack of 'apt install' stuff needed to build kodi my way, and I'll do it using the minimal amount of packages possible, -dev only, etc. )
RE: How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI - by fosf0r - 12-17-2018, 11:57 AM
  RockPro64 - HDMI and higher resolutions PakoSt 0 1,387 11-16-2021, 03:48 PM
Last Post: PakoSt
  OMV to Kodi Streaming Issues cogito808 12 17,254 05-25-2021, 08:30 AM
Last Post: helpmerock
  RockPro64 Linux Manjaro HDMI 4K mkne 12 14,815 05-03-2020, 07:23 AM
Last Post: PakoSt
  Debian, Kodi and the Spotify plugin. Pineapple 1 2,919 10-14-2019, 10:02 PM
Last Post: SBCraok
  Linux distro that will work with Kodi? SBCraok 9 12,009 09-18-2019, 02:12 AM
Last Post: mtrcycllvr
  Does anyone have kodi working? blahblahblah 6 7,390 07-19-2019, 08:09 AM
Last Post: PackElend
  issue with kodi freezing randomly Slam 3 3,960 05-24-2019, 03:53 PM
Last Post: mknawabi
  HDMI audio solved yoramro 2 5,630 01-29-2019, 10:01 PM
Last Post: fczuardi
  kodi and /dev/rkdev catalinii 0 2,331 08-09-2018, 10:38 PM
Last Post: catalinii
