HDMI audio solved
If you are unable to hear HDMI audio with your rockpro64 and the latest Linux release, you need to follow the instructions on setting PulseAudio default audio output
https://wiki.archlinux.org/index.php/Pul...put_source
Once you set the default to the HDMI, your audio will be routed to your HDMI monitor / TV
BTW - this also fixed the double playing speed on YouTube. Playing is at normal speed
Good luck
Yoram
Hmm - not sure if I am on the same page. If I run
$ uname -a
Linux rpro64.dukla.net 4.4.154-1122-rockchip-ayufan-g7859b9b904a9 #1 SMP Mon Oct 1 07:32:42 UTC 2018 aarch64 aarch64 aarch64 GNU/Linux
I now have all kinds of sound problems that I never had with 4.4.132. In short
1) If pulseaudio is installed then any ALSA access (e.g. aplay -l) causes a complete hang
2) If pulseaudio is NOT installed then sound through HDMI is fine for 1 use only. Thereafter it does not play and the log collects
[   82.081872] rockchip-i2s ff8a0000.i2s: fail to clear
[   82.352420] rockchip-i2s ff8a0000.i2s: fail to clear
[   82.609699] rockchip-i2s ff8a0000.i2s: fail to clear
[   82.868824] rockchip-i2s ff8a0000.i2s: fail to clear
[   83.116015] rockchip-i2s ff8a0000.i2s: fail to clear
[   83.336821] rockchip-i2s ff8a0000.i2s: fail to clear
[   83.589797] rockchip-i2s ff8a0000.i2s: fail to clear
[   83.825620] rockchip-i2s ff8a0000.i2s: fail to clear
[   84.099204] rockchip-i2s ff8a0000.i2s: fail to clear
[   84.344286] rockchip-i2s ff8a0000.i2s: fail to clear
[   84.599575] rockchip-i2s ff8a0000.i2s: fail to clear
[   84.833863] rockchip-i2s ff8a0000.i2s: fail to clear
[   85.073684] rockchip-i2s ff8a0000.i2s: fail to clear
[   85.341227] rockchip-i2s ff8a0000.i2s: fail to clear
[   85.600059] rockchip-i2s ff8a0000.i2s: fail to clear
[   85.816456] rockchip-i2s ff8a0000.i2s: fail to clear
[   86.074480] rockchip-i2s ff8a0000.i2s: fail to clear
[   86.379318] rockchip-i2s ff8a0000.i2s: fail to clear
[   86.608908] rockchip-i2s ff8a0000.i2s: fail to clear
[   86.701377] rockchip-i2s ff8a0000.i2s: fail to clear
[   87.092289] rockchip-i2s ff8a0000.i2s: fail to clear
[   87.336053] rockchip-i2s ff8a0000.i2s: fail to clear
[   87.557827] rockchip-i2s ff8a0000.i2s: fail to clear
[   87.813607] rockchip-i2s ff8a0000.i2s: fail to clear
[   88.046203] rockchip-i2s ff8a0000.i2s: fail to clear
[   88.297553] rockchip-i2s ff8a0000.i2s: fail to clear
[   88.534697] rockchip-i2s ff8a0000.i2s: fail to clear
[   88.749587] rockchip-i2s ff8a0000.i2s: fail to clear
[   89.004934] rockchip-i2s ff8a0000.i2s: fail to clear
[   89.251929] rockchip-i2s ff8a0000.i2s: fail to clear
[   89.484743] rockchip-i2s ff8a0000.i2s: fail to clear
[   89.740515] rockchip-i2s ff8a0000.i2s: fail to clear
[   89.995896] rockchip-i2s ff8a0000.i2s: fail to clear
[   90.251861] rockchip-i2s ff8a0000.i2s: fail to clear
[   90.503867] rockchip-i2s ff8a0000.i2s: fail to clear
[   90.759484] rockchip-i2s ff8a0000.i2s: fail to clear
[   90.991677] rockchip-i2s ff8a0000.i2s: fail to clear
[   91.252414] rockchip-i2s ff8a0000.i2s: fail to clear
[   91.448860] rockchip-i2s ff8a0000.i2s: fail to clear
[   91.683505] rockchip-i2s ff8a0000.i2s: fail to clear
[   91.764983] rockchip-i2s ff8a0000.i2s: fail to clear
Updating this thread since it is the first google result for "rockpro64 hdmi audio"...
In my case I had to change my kernel to 4.4.138-1100-rockchip-ayufan-g95cecee47f40 to finally make HDMI audio work. Many other kernels were just emitting a high pitch cricketing-like sound and slowing down videos.
To get the image with the good kernel you ca use:
sudo apt install linux-image-4.4.138-1100-rockchip-ayufan-g95cecee47f40
And then use the change-default-kernel.sh script to select it:
sudo su
 . /usr/local/sbin/change-default-kernel.sh
reboot
If your /usr/local/sbin don't have the change-default-kernel script, you can update to the pre-release train by uncommenting the line on /etc/apt/sources.list.d/ayufan-rock64.list
then:
sudo apt-get update -y
sudo apt-get install linux-rock64 -y
sudo apt-get install linux-rockpro64 -y
yay! sound!
  A fix for Bluetooth audio stuttering on the RockPro64 raph 2 1,669 01-03-2023, 06:53 PM
Last Post: raph
  SPDIF output audio gaps jssfr 2 1,739 07-24-2022, 06:26 AM
Last Post: jssfr
  RockPro64 - HDMI and higher resolutions PakoSt 0 1,359 11-16-2021, 03:48 PM
Last Post: PakoSt
  No audio output with Manjaro Arm 20.04 Faradn 2 4,435 08-02-2020, 09:48 AM
Last Post: new-rockpro-user
  RockPro64 Linux Manjaro HDMI 4K mkne 12 14,579 05-03-2020, 07:23 AM
Last Post: PakoSt
  RockPro64 getting started - non-booting images [solved] new-rockpro-user 3 6,120 03-06-2020, 06:31 AM
  new rockpro64: images won't boot [solved] new-rockpro-user 0 2,437 11-20-2019, 12:42 PM
Lightbulb How-To, non-X11: Get 4K (>2560x1600) framebuffer, DRM, GBM, Kodi on HDMI fosf0r 14 17,545 12-17-2018, 11:57 AM
Last Post: fosf0r
  [SOLVED] No sound from phone-jack via "es8316" on rockpro64 t4_4t 14 19,868 11-28-2018, 04:32 PM
Last Post: dukla2000
  RockPro64 and 802.1q support [Solved] divek 2 3,065 11-04-2018, 11:15 AM
Last Post: divek
