Mali GPU utilisation check
(11-15-2018, 12:26 AM)rahulsharma Wrote: Hi,
I built a object detection project that uses Arm Cmpute library on rockpro64.
How can i check whether Mali GPU is being utilised or not. Any command?
Thanks.
The ARM Compute Library has some tools, examples and so on.
Its there a Tutorial, but its for Lua Language  a clinfo.
OpenCL
Mali GPU utilisation check - by rahulsharma - 11-15-2018, 12:26 AM
RE: Mali GPU utilisation check - by tuxd3v - 11-15-2018, 09:02 AM
RE: Mali GPU utilisation check - by rahulsharma - 11-16-2018, 12:49 AM
RE: Mali GPU utilisation check - by fosf0r - 11-28-2018, 03:23 PM
RE: Mali GPU utilisation check - by fosf0r - 11-29-2018, 10:13 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 704 08-14-2023, 07:55 AM
Last Post: kundanjha
  rtc battery check rahulsharma 0 1,605 01-15-2019, 09:05 AM
Last Post: rahulsharma
