Open media vault on pine64?
(05-05-2016, 11:30 PM)frewind Wrote:
(04-17-2016, 06:17 PM)Luke Wrote: Hey everyone,
Having toyed around with the pine64 for a couple of weeks, I feel that now I zeroed in on a real day-to-day purpose for it. I want it to act as a NAS/ sync server. While I know that I could just get BitTorrent sync + samba installed on it and live happily ever after, I am wondering if it would be possible to build omv for the pine64. From what I remember omv uses Debian (right?) and not Ubuntu - hence my question, would it be possible to install omv on top of ubuntu?
 Cheers,
Luke
Hi Luke,
When you say "would be possible to build omv for the pine64", what exactly do you have in mind? Are you suggesting a omv image a user can simply download, burn and boot, then have a wizard type walk-through to get it up and running?
I ask as I've always thought the real advantage of ovm was it really does do what they say in the project readme... "simple and easy to use out-of-the-box solution"
If that is the goal then I would very much support the idea..
To answer the Debian question, the Debian Jessie Images (3.10.65 BSP Kernel) is up and running (all be it with the currently linux limitations), so I guess the first thing to do is a manual install of the required packages, omv framework and plugin's and see what run's.
I suspect there will be lots of opportunities to overcome challenges Smile ... If enough people are interested we should give it a go....
Thank you for responding frewind!
Yes, I now know that there is a debian img, and if I've known this earlier I would have manually installed the framework and packages.
Both my pine64's have now their assigned purposes (one an irc server - see sig; the other a wordress server), but I may just get another one (or two) in the coming months and will then make it into a omv server Smile
Lets stay in touch !
Open media vault on pine64? - by Luke - 04-17-2016, 06:17 PM
RE: Open media vault on pine64? - by Suprazz - 05-05-2016, 05:56 PM
RE: Open media vault on pine64? - by frewind - 05-05-2016, 11:30 PM
RE: Open media vault on pine64? - by Luke - 05-06-2016, 05:52 AM
RE: Open media vault on pine64? - by tkaiser - 05-06-2016, 06:05 AM
RE: Open media vault on pine64? - by Luke - 05-06-2016, 06:10 AM
RE: Open media vault on pine64? - by tkaiser - 05-06-2016, 06:19 AM
RE: Open media vault on pine64? - by Luke - 05-06-2016, 07:04 AM
RE: Open media vault on pine64? - by tkaiser - 05-06-2016, 07:31 AM
RE: Open media vault on pine64? - by frewind - 05-06-2016, 12:58 PM
  Open Media Vault - Help needed janeku 3 4,921 04-01-2021, 06:36 AM
  Programming languages support under PINE64 baryluk 6 12,433 09-23-2020, 11:46 PM
Last Post: Phillip Bell
  Manjaro arm on pine64+ roel 2 5,957 10-19-2019, 05:13 AM
Last Post: roel
  Volumio for PINE64 Released mikelangeloz 11 24,643 03-22-2019, 09:25 AM
Last Post: llungster
  I2S Audio patches for Pine64+ uploaded to GitHub ramstadt 1 4,071 01-19-2019, 11:31 AM
Last Post: ramstadt
  Pine64: Minimal SDL config Max11 3 6,043 01-04-2019, 03:47 PM
Last Post: Max11
  Fedora 27 on Pine64 gregjo 18 35,603 01-02-2019, 10:42 PM
Last Post: heatfanjohn
  Official build procedure of ayufan pine64 r.tanaka 0 3,130 08-21-2018, 10:54 PM
Last Post: r.tanaka
  DKMS on kernel 3.10.107-pine64 obrienmd 5 8,716 06-21-2018, 05:45 PM
Last Post: evilbunny
  Gentoo for pine64 - longsleep kernel incoherent 0 3,657 12-09-2017, 08:14 AM
Last Post: incoherent
