PCIe Inconsistency Problems
I've posted this in another thread:
(10-20-2018, 05:36 AM)jja2000 Wrote:
(10-15-2018, 05:28 AM)jja2000 Wrote: I've been having trouble getting my Pine bought PCIe SATA card to work aswell.
It used to show up before but then totally disappear. The HDD spins up but does not show up in lsblk or in dmesg. There's no LED burning on the card. The HDD works aswell.
Doing a dmesg | grep pci gives me this:
rock64@rockpro64:~$ dmesg | grep pci
[    0.498071] of_get_named_gpiod_flags: parsed 'gpio' property of node '/vcc3v3-pcie-regulator[0]' - status (0)
[    0.498129] reg-fixed-voltage vcc3v3-pcie-regulator: Looking up vin-supply from device tree
[    0.498167] vcc3v3_pcie: supplied by dc_12v
[    0.498232] vcc3v3_pcie: 3300 mV
[    0.498386] reg-fixed-voltage vcc3v3-pcie-regulator: vcc3v3_pcie supplying 3300000uV
[    1.177078] ehci-pci: EHCI PCI platform driver
[    2.656712] vcc3v3_pcie: disabling
[    3.114214] phy phy-pcie-phy.9: Looking up phy-supply from device tree
[    3.114218] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed
[    3.292837] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep
[    3.292852] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup
[    3.292902] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0)
[    3.293278] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[    3.293470] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[    3.293483] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[    3.293518] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    3.302175] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[    3.302195] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[    3.302230] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    3.313324] rockchip-pcie f8000000.pcie: invalid power supply
[    3.820353] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    3.830861] rockchip-pcie: probe of f8000000.pcie failed with error -110
Okay so I installed mainline and I get a similar error:
[    1.709157] vcc3v3_pcie: supplied by dc_12v
[    2.994902] ehci-pci: EHCI PCI platform driver
[    3.051118] ohci-pci: OHCI PCI platform driver
[    3.468181] vcc3v3_pcie: disabling
[    6.753355] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
[    6.753416] rockchip-pcie f8000000.pcie: Linked as a consumer to regulator.3
[    6.753431] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[    6.753441] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[    7.308970] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
[    7.309707] rockchip-pcie f8000000.pcie: Dropping the link to regulator.3
[    7.309778] rockchip-pcie: probe of f8000000.pcie failed with error -110
But it happens a lot less consistently, mostly reboots and a bit of reseating of the cables makes it function again.
When it does work and I try to access the harddrive (either by mounting or by opening a partition manager via ssh) the board (presumeably, because I have no display output on Mainline and no way to read the GPIO pins for serial) kernel panics.
It kinda sucks that I can't use this device as intended. Anyone have a suggestion to make this work?
PCIe Inconsistency Problems - by jja2000 - 10-21-2018, 06:39 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-21-2018, 11:29 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 10:48 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:06 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 11:11 AM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 11:23 AM
RE: PCIe Inconsistency Problems - by jja2000 - 10-22-2018, 01:27 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-22-2018, 02:19 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-22-2018, 09:22 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:31 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:32 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-23-2018, 12:35 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-23-2018, 12:54 PM
RE: PCIe Inconsistency Problems - by jannerman - 10-24-2018, 11:52 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 01:16 PM
RE: PCIe Inconsistency Problems - by Bullet64 - 10-29-2018, 02:12 PM
RE: PCIe Inconsistency Problems - by jja2000 - 10-29-2018, 02:49 PM
RE: PCIe Inconsistency Problems - by TheHunter - 11-16-2018, 06:07 PM
RE: PCIe Inconsistency Problems - by jja2000 - 12-17-2018, 01:39 PM
  RK3399 PCIe enumeration jhadd 0 319 01-31-2024, 08:56 AM
Last Post: jhadd
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,298 10-14-2022, 06:24 AM
Last Post: rwk-
  No PCIe controller detected... Limhes 1 1,647 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 1,883 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 1,437 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 6,983 05-20-2021, 10:04 PM
Last Post: t4_4t
  Problems with my RockPro64 tuxd3v 0 1,934 08-19-2020, 11:47 AM
Last Post: tuxd3v
  Frequent kernel panic, possibly due to PCIe SSD? meier 4 6,055 11-22-2019, 05:15 PM
Last Post: meier
  My PCIe disk controller works with Linux 5.3.6 guannais 1 2,800 10-30-2019, 07:11 PM
Last Post: guannais
Information Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D Luke 100 128,456 10-04-2019, 08:57 PM
Last Post: tuxd3v
