My PCIe disk controller works with Linux 5.3.6
As said in the title, I have a disk controller LSI 9208 8i that needed some patch (pcie_rk_delay_bus_scan) to work with kernel Rockchip line 4.4 (the patch is in ayufan's kernel since april). I tried again the mainline and, finally, it works out of the box with the version 5.3.6. By the way, I have not tested Panfrost graphic driver, and I could not make framebuffer console to work.
I had problems with TCP conections from the Rockpro64 box with TVheadend to other computers with Kodi. Sometimes, the connection just stalled with a dumb conversation between peers like this:
PC: I confirm byte 12000 received (send me more).
Rockpro64: Take bytes 12001-15000.
PC: ...
Rockpro64: Take bytes 15001-18000.
Rockpro64:  Dodgy
Perhaps the ethernet driver in Linux 5.3 is buggy and miscrafts some frames. I fixed it by disabling TCP checksum offload:
# ethtool -K eth0 tx off
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 1 501 03-25-2024, 12:12 PM
  RK3399 PCIe enumeration jhadd 0 278 01-31-2024, 08:56 AM
Last Post: jhadd
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 841 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 1,311 07-14-2023, 04:22 AM
Last Post: hunderteins
  Linux laptop does not detect the board when plugged in via USB soupy 1 4,010 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 2,206 10-14-2022, 06:24 AM
Last Post: rwk-
  RockPro64 linux console video mode callegar 0 885 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 8,225 04-30-2022, 03:57 PM
Last Post: TRS-80
  How I Got Fedora Linux to Boot From eMMC (or microSD, for that matter) whitecat23 4 4,291 01-03-2022, 10:32 AM
Last Post: whitecat23
  No PCIe controller detected... Limhes 1 1,594 11-23-2021, 06:23 AM
Last Post: Limhes
