Gentoo, Current state, Test Phase
(10-06-2018, 07:37 AM)khaosgrille Wrote:
(10-06-2018, 07:23 AM)zener Wrote: I gave it a try, but I does not respond to ping when I boot.
The Ubuntu image responds to ping and let me log in on ssh. But the gentoo image does not even respond to ping.
Is it set up to run DHCP?
Thanks!
Nope I didnt do it/ tried it yet. I will make a new image with DHCP setup. Since I am busy right now it may take 2 weeks or so.
If you use a microSD card of smaller size the kernel will complaint that part of the filesystem is outside the device. You will have to make a custom disk image, copy the first 6 partitions, create the 7th, format it as your favourite filesystem, mount it, and copy the files.
-Unpack the file, let's to use sparse files to avoid wasting disk space with zeroes
$ xz -dc gentoo2.xz | dd of=gentoo2 conv=sparse
-Check the partition table with "parted"
$ parted gentoo2
(parted) unit b
(parted) print
Model:  (file)
Disk /home/jose/rockpro64/stretch-minimal-rockpro64-0.7.9-1067-arm64.img: 2144337920B
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start       End          Size         File system  Name       Flags
 1      32768B      4128767B     4096000B                  loader1
 2      4128768B    4194303B     65536B                    reserved1
 3      4194304B    8388607B     4194304B                  reserved2
 4      8388608B    12582911B    4194304B                  loader2
 5      12582912B   16777215B    4194304B                  atf
 6      16777216B   134217727B   117440512B   fat16        boot       msftdata
 7      134217728B  2143289343B  2009071616B  ext4         root       legacy_boot
(parted) quit
-Create an empty disk image for your SD card, for example 16000000000 bytes
$ truncate -s 16000000000 sd.raw
-Copy the partition table and the first 6 partitions
$ dd if=gentoo2 of=sd.raw bs=134217728 count=1
-Make the filesystem for the seventh partition
$ mke2fs -t ext4 -E offset=134217728 sd.raw $[16000000000-134217728]
-Become root
-Mount the 7th partition of both images
# mkdir tmp tmp2
# mount -o loop,offset=134217728 gentoo2 tmp
# mount -o loop,offset=134217728 sd.raw tmp2
-Copy the files
# cp -a tmp/* tmp2
-Unmount
# umount tmp
# umount tmp2
# rmdir tmp tmp2
-Done
RE: Gentoo is working - by Pitcrawler - 09-26-2018, 06:28 AM
RE: Gentoo is working - by evilbunny - 09-26-2018, 06:28 AM
RE: Gentoo is working - by zener - 10-06-2018, 07:23 AM
RE: Gentoo is working - by khaosgrille - 10-06-2018, 07:37 AM
RE: Gentoo is working - by guannais - 10-06-2018, 05:42 PM
RE: Gentoo is working - by zener - 10-06-2018, 02:52 PM
RE: Gentoo is working - by zener - 10-07-2018, 12:08 AM
RE: Gentoo is working - by tux_on_tour - 10-26-2018, 05:50 AM
RE: Gentoo is working - by khaosgrille - 11-21-2018, 01:34 PM
RE: Gentoo is working - by tux_on_tour - 11-26-2018, 05:16 AM
RE: Gentoo is working - by khaosgrille - 12-28-2018, 04:42 PM
  How to reset board to default state? kkdao 4 6,083 09-01-2020, 05:48 AM
Last Post: kkdao
  Anyone running Gentoo? N1ESE 1 3,671 05-12-2020, 07:27 AM
Last Post: khaosgrille
  Call for test: Clonezilla live for Rockpro64 stevenshiau 1 4,824 04-17-2020, 12:38 AM
  ARM CPU Stress Test jzhang18 14 17,065 08-31-2018, 12:54 PM
Last Post: jzhang18
