Anyone running Gentoo?
I'm looking to upgrade from a Raspberry Pi 4 2GB to a RockPro64 4GB.
Is anyone running Gentoo?  I did a forum search but only found one user working on an image back in 2018 but didn't seem to get too far.
I mostly need to figure out how to get a minimal stage3 to boot and I can probably figure out the rest from there.
Thanks.
(04-20-2020, 04:35 PM)N1ESE Wrote: I'm looking to upgrade from a Raspberry Pi 4 2GB to a RockPro64 4GB.
Thanks.
hi
i did no update since it is nearly working out of the box. i recommend using ayufans 5.6 kernel. i got X with i3 working. as minimal stage3 i recommend the official arm64 stage3 (http://distfiles.gentoo.org/experimental/arm64/.  my only problem currently are some minor compile errors every now and than.
  Armbian Jammy-Running fairly stable Rocklobster 0 1,182 05-04-2022, 01:00 PM
Last Post: Rocklobster
Question Help getting a GPU running on my RockPro64 Ceazer 0 1,630 11-23-2020, 04:05 PM
Last Post: Ceazer
  Gentoo, Current state, Test Phase khaosgrille 12 15,163 06-23-2019, 07:14 PM
Last Post: necrose99
